IPad Wifi and No GPS Data
jay_hl
jay_hl
Posts: 7, Visits: 75
I have an iPad 2 wifi only and the full blown Sky Demon (with all the add ons). I think it's a fab piece of software for planning, but I'm having a nightmare with it in Nav mode.
I bought a bad elf pro (the separate device, not plug in) to provide Sky Demon with GPS data. It has a screen on the GPS unit so you can see the read out (which is good as an ultimate last resort and back up!).
I've connected the two via Bluetooth fine and used the Bad Elf app on the iPad to see the output of the GPS unit which works fine.
When I go into Sky Demon in "Go Flying" mode it shows as a red aircraft symbol which I understand means that GPS data is not being fed to Sky Demon at least once a second.
When I connect my ipad by wifi, the aircraft turns yellow and it seems to work and being provided by GPS data.
I have ensured that Location Services for Sky Demon are switched on.
I've searched the forums and tried various Privacy resets, and checking setting with no solution.
I'm desperate to get this sorted, so any help would be appreciated.
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
Possibly, but as long as you closed the app, the location services will have timed out by the time you get to the airfield.
I think the key point is - "don't connect your bluetooth if the little location services pointer is already visible"
That has made connections 100% reliable for me (Dual XGPS150)
icare75
icare75
Too Much Forum (148 reputation)Too Much Forum (148 reputation)Too Much Forum (148 reputation)Too Much Forum (148 reputation)Too Much Forum (148 reputation)Too Much Forum (148 reputation)Too Much Forum (148 reputation)Too Much Forum (148 reputation)Too Much Forum (148 reputation)
Posts: 1, Visits: 7
I did also have the same issue with an Ipad2 wifi and pairing a bluetooth DUAL XGPS150. It worked fine even in "airline mode" (and bluetooth switch in "on" mode) until I update to 6.1. I'm using my gps with Jepp FD and Skydemon simultaneously, with no bug. Then after the IOS update, everything went wrong. Neither, the Jepp FD or Sydemon's app were able to connect to the GPS. What i did is, delete all navigation apps on my ipad such as skydemon / Jepp FD / etc... as well as the Dual GPS Apps. Reboot my ipad and reinstall the apps. Now everything is back to normal.
PS: I did call apple on this matter, they have no issue, I'm pretty sure that's an IOS issue though
jay_hl - 5/23/2013 9:28:17 AM
stevelup - 5/23/2013 2:56:44 PM
jay_hl - 5/24/2013 8:07:21 PM
jay_hl - 5/26/2013 10:40:17 AM
cct - 5/26/2013 5:15:08 PM
jweitner - 5/26/2013 11:24:36 PM
jweitner - 5/26/2013 11:51:04 PM
cct - 5/27/2013 10:52:29 PM
jay_hl - 5/27/2013 12:06:31 PM
WinHern - 5/27/2013 10:16:35 PM
stevelup - 5/27/2013 10:35:28 PM
jweitner - 5/27/2013 11:16:56 PM
stevelup - 5/28/2013 7:36:46 AM
jweitner - 5/28/2013 9:17:34 PM
                         It looks like you solved my problem! Many thanks! Really great!...
stevelup - 5/28/2013 10:41:59 PM
                             Good news. Skydemon is working perfect so is the data app! It worked...
jweitner - 5/30/2013 7:21:41 AM
                                 It's all moderately useless stuff so I wouldn't worry too much about...
stevelup - 5/30/2013 8:32:18 AM
jweitner - 5/28/2013 9:17:42 PM
jay_hl - 5/28/2013 9:52:07 AM
stevelup - 5/28/2013 1:03:30 PM
Tim Dawson - 5/28/2013 11:27:29 AM
PeteB - 5/28/2013 2:31:40 PM
stevelup - 5/28/2013 2:37:29 PM
PeteB - 5/28/2013 2:50:11 PM
stevelup - 5/28/2013 3:42:35 PM
                         Hi, I did also have the same issue with an Ipad2 wifi and pairing a...
icare75 - 5/28/2013 9:37:25 PM
jay_hl - 5/30/2013 10:04:06 AM
