SkyDemon Navigation
IPad Wifi and No GPS Data
Prev
1
2
3
Jump To Page
jweitner
jweitner
posted 5/28/2013 9:17:34 PM
Visits: 20
@ Stevelup
I am using version 6.1.3.
I did your tests and found that both the 'GPS data' and Skydemon are now working fine without wifi. The red dot is flickering multiple times per second. The GPS data is changing while moving and also the groundspeed in Skydemon and other variables show values.
It looks like you solved my problem! Many thanks! Really great!
I am curious if it will remain like this. I am flying tomorrow so let's see what happens!
Jan
jweitner
jweitner
posted 5/28/2013 9:17:42 PM
Visits: 20
@ Stevelup
Jan
icare75
icare75
posted 5/28/2013 9:37:25 PM
Visits: 7
I did also have the same issue with an Ipad2 wifi and pairing a bluetooth DUAL XGPS150. It worked fine even in "airline mode" (and bluetooth switch in "on" mode) until I update to 6.1. I'm using my gps with Jepp FD and Skydemon simultaneously, with no bug. Then after the IOS update, everything went wrong. Neither, the Jepp FD or Sydemon's app were able to connect to the GPS.
What i did is, delete all navigation apps on my ipad such as skydemon / Jepp FD / etc... as well as the Dual GPS Apps. Reboot my ipad and reinstall the apps. Now everything is back to normal.
PS: I did call apple on this matter, they have no issue, I'm pretty sure that's an IOS issue though
Tags
Ipad wifi GPS bug
posted 5/28/2013 10:41:59 PM
Visits: 4.9K
Yay - good news. Let us know how you get on tomorrow!
Edited
5/28/2013 10:47:33 PM by
jweitner
jweitner
posted 5/30/2013 7:21:41 AM
Visits: 20
Good news. Skydemon is working perfect so is the data app! It worked excellent!
Your solution works Stevelup!
Many thanks for your help!
Now I am curious how everything will continue to work once I will put more Location services back to 'on'. We'll see!
Jay how is it going with your issue?
posted 5/30/2013 8:32:18 AM
Visits: 4.9K
It's all moderately useless stuff so I wouldn't worry too much about turning it back on!
For the record, the only one I have turned off though is 'Automatically set time zone' - that fixed it for me. It also increased battery life.
The important thing is to make sure the location services arrow is not visible on the screen before you pair the bluetooth device. Turning the above stuff of just helps you take control of that.
jay_hl
jay_hl
posted 5/30/2013 10:04:06 AM
Visits: 75
Yes Im up and running now. Had to try the work around a couple of times, but now my red light flashes about 1 a second. Im so happy. Time to use it for the first time this weekend!
Thanks for the replies guy. Appreciate it.
Prev
1
2
3
Jump To Page
