vikino
v
Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)Too Much Forum (497 reputation)
Posts: 33, Visits: 85
Hi all, there has been a lot of discussions about this, but never resulted in any way.
Is it possible, somehow, to get out from SkyDemon over bluetooth to RS232 converter some data?
From my current Aera 760 i have over serial port connected autopilot and Trig radio so Aera can feed AP with planned track and when i click on airfields com freq it sets stand by freq. But, it is Garmin and their weird navigation point stupid names, airfields without names and so on...
This will be nice to have on SkyDemon, are there some possibilities?
Vitek
Linoair
L
Posts: 5, Visits: 0
Final glide - 12/26/2024 7:00:01 PM
Hi ulli It is super simple pins 1,2,and 9 for the av-30 And that’s it select autopilot and all on the SD it does 9600 bad automatically You can test by using the simulator function on SDBrilliant system !!!!!
Hi Final Glide,
we have an installation with one iPad (running SD), one AV-30 and one KRT2. We just bought a BT dongle to send frequencies to the KRT2. Did you manage to use the same dongle to simultaneously transfer Nav data from SD to the AV-30?
That would be really amazing. Or do you need a second BT Adapter for the AV30???
Thank you in advance,
Stephan
IO390
I
Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)
Posts: 3, Visits: 0
The software on the standalone version of my BT module supports routing certain message formats to each serial port, so in theory you could connect a Funke radio and an AV30 to just the one BT module. I’ve not got any equipment to test this though (my aircraft has a G3X and one Trig radio) so I can’t sell it without a full shakedown and test.
Michael Hoffmann
Michael Hoffmann
Posts: 48, Visits: 23
Linoair - 4/19/2025 8:53:46 AM
Hi Final Glide,
Stephan
The data streams must be isolated. The data from the autopilot must not reach the KRT2, otherwise the radio will misinterpret it and no longer function correctly.
So either 2 separate adapters, or separate the data streams using a microcontroller and output them to 2 different ports. I think the solution with 2 BLE adapters is simpler, cleaner and cheaper.
Linoair
L
Posts: 5, Visits: 0
Michael Hoffmann - 4/20/2025 12:00:27 PM
Hi Final Glide,
Stephan
Dear Final Glide and dear Michael,
thank you for your quick response.
@Michael: The experience with the KRT 2 SD-Link (quality, installation effort, documentation and also pricing) was so great, that I would definitely also buy your AV-30 Adapter as soon as it is available. Do you think it might be possible to use it on top of the AV-Link Wifi-Adapter, which receives our GDL90 Traffic Data Stream? I think AV Link uses a different Pin to transfer the traffic data to the AV-30!?
I did not expect, the all this might be available :-)
Happy Easter,
Stephan
Edited 4/20/2025 6:08:42 PM by Linoair
Michael Hoffmann
Michael Hoffmann
Linoair - 4/20/2025 3:28:02 PM
Happy Easter,
Stephan
Stephan,
the wait is over. The SD-Link AV-30 adapter is now available. This will turn your uAvionix AV-30 into an HSI displaying the planned SkyDemon legs. The existing AV-Link for the traffic display will continue to function ;-)
It's a simple "plug and play adapter", just plug it in and enjoy the new features.
Here is more information:
Cheers!
Michael
vikino - 6/1/2023 5:02:31 AM
Tim Dawson - 6/1/2023 9:53:32 AM
vikino - 6/1/2023 12:34:32 PM
Tim Dawson - 6/2/2023 10:07:02 AM
Skyboy999 - 7/4/2023 7:08:16 AM
     It could.
Tim Dawson - 7/4/2023 8:46:16 AM
Skyboy999 - 7/4/2023 12:46:37 PM
Tim Dawson - 7/5/2023 9:13:53 AM
jekroth - 9/19/2024 9:04:27 PM
jekroth - 11/15/2024 3:07:38 PM
Laycom - 11/18/2024 8:44:51 PM
vikino - 11/23/2024 11:20:57 AM
                         Well, RS232 is defined as a bidirectional point-to-point connection....
Laycom - 11/23/2024 3:10:34 PM
                             If becker needs to send back (dont understand why, because it should...
vikino - 11/24/2024 1:43:26 PM
                                 Becker can only control both frequencies in one command, so you need...
Laycom - 11/24/2024 6:00:06 PM
jekroth - 12/6/2024 8:36:23 PM
vikino - 8/4/2023 7:57:32 PM
vikino - 8/8/2023 8:27:57 PM
vikino - 8/28/2023 7:08:25 PM
Dortro - 12/20/2024 1:20:06 PM
Wolfram Schiffmann - 12/6/2024 6:02:22 PM
Tim Dawson - 8/29/2023 9:38:00 AM
vikino - 8/29/2023 5:46:42 PM
vikino - 9/28/2023 7:11:38 AM
vikino - 9/15/2023 7:59:23 AM
Marc25 - 9/25/2023 2:10:44 PM
vikino - 9/25/2023 2:27:28 PM
vikino - 3/10/2024 12:08:26 PM
Tim Dawson - 3/11/2024 10:37:15 AM
Bouwair - 4/25/2024 12:12:20 PM
vikino - 4/25/2024 5:06:31 PM
Tim Dawson - 5/8/2024 10:38:34 AM
vikino - 5/8/2024 11:53:31 AM
Tim Dawson - 5/8/2024 1:26:00 PM
             The first one
vikino - 5/8/2024 1:44:14 PM
Tim Dawson - 5/8/2024 2:25:43 PM
vikino - 5/8/2024 3:51:06 PM
Tim Dawson - 5/9/2024 8:58:04 AM
vikino - 5/9/2024 8:26:38 PM
gs-avionik.de - 5/10/2024 10:25:26 AM
vikino - 5/11/2024 11:50:57 AM
Tim Dawson - 5/22/2024 1:36:08 PM
             Wozld be great to have GPRMC too
vikino - 5/27/2024 11:27:45 AM
vikino - 5/27/2024 9:23:18 PM
Tim Dawson - 5/28/2024 9:09:41 AM
Tim Dawson - 6/12/2024 8:55:23 AM
Skyboy999 - 6/21/2024 7:42:30 AM
vikino - 7/30/2024 3:00:56 PM
Tim Dawson - 6/21/2024 8:45:54 AM
Skyboy999 - 6/22/2024 7:30:09 AM
Tim Dawson - 6/24/2024 10:15:34 AM
Skyboy999 - 6/25/2024 7:47:03 AM
vikino - 8/5/2024 4:21:43 PM
Tim Dawson - 6/25/2024 9:07:25 AM
ph-crj - 8/20/2024 4:30:15 PM
aerobatics500 - 8/26/2024 5:39:26 PM
ph-crj - 8/26/2024 8:04:47 PM
vikino - 8/28/2024 12:25:15 PM
                         Yesterday my perfekt working installation went crasy. :-( The TRIO...
ph-crj - 8/28/2024 1:46:20 PM
                             Caveat all those who wish to hand over control of an aircraft to...
grahamb - 8/28/2024 5:10:57 PM
                                 I have an uncertified engine and the uncertfied Version of the Garmin...
ph-crj - 8/29/2024 9:57:34 AM
mbechc - 8/21/2024 7:31:05 AM
Tim Dawson - 8/21/2024 9:17:31 AM
Bouwair - 8/21/2024 9:25:53 PM
Tim Dawson - 8/22/2024 8:20:06 AM
             Sorry, Did not read the latest manual
Bouwair - 8/25/2024 9:36:33 PM
I_Need_Help - 8/22/2024 7:11:07 PM
Tim Dawson - 8/23/2024 9:30:52 AM
             Thanks Tim
I_Need_Help - 8/29/2024 9:08:32 PM
I_Need_Help - 9/2/2024 3:28:07 PM
                 We are advertising the service UUID 0xFFE0...
I_Need_Help - 9/2/2024 7:55:39 PM
tmn_pilot - 8/26/2024 10:12:59 AM
Laycom - 8/26/2024 8:12:27 PM
bsdchapman - 9/14/2024 10:51:58 AM
Tim Dawson - 8/27/2024 8:59:31 AM
Laycom - 8/27/2024 5:38:14 PM
Tim Dawson - 8/28/2024 8:57:48 AM
             Got it. Thanks.
Laycom - 8/28/2024 6:26:11 PM
Kilo Lima - 8/28/2024 5:00:33 PM
             Any idea please? Thanks for your help!
Kilo Lima - 9/3/2024 9:12:11 AM
I_Need_Help - 9/3/2024 9:15:58 AM
Kilo Lima - 9/3/2024 9:09:19 PM
Kilo Lima - 9/3/2024 9:11:38 PM
davemg - 8/29/2024 8:36:03 AM
Tim Dawson - 8/29/2024 8:53:45 AM
aerobatics500 - 8/31/2024 8:27:16 AM
PaulSS - 8/31/2024 8:35:48 AM
aerobatics500 - 8/31/2024 1:18:28 PM
Tim Dawson - 9/2/2024 9:54:50 AM
PaulSS - 9/2/2024 2:21:03 PM
Tim Dawson - 9/3/2024 9:19:57 AM
norland - 9/3/2024 11:37:27 AM
Laycom - 10/14/2024 8:59:32 PM
Pascal - 10/16/2024 4:54:09 PM
Laycom - 10/16/2024 7:52:23 PM
                         Becker does offer its own rs232 to rs 422 converter (available for...
Pascal - 10/17/2024 3:06:44 PM
                             I would guess it's only the hardware converter (on ebay a few...
Laycom - 10/17/2024 7:09:35 PM
                         What shape or form would a Becker “Translator” take? Lines of code...
Pascal - 10/17/2024 3:10:02 PM
                             Well, it depends ;-)) If Skydemon could add this type of device in...
Laycom - 10/17/2024 7:28:49 PM
Kilo Lima - 9/3/2024 9:14:07 PM
I_Need_Help - 9/4/2024 11:01:15 AM
Kilo Lima - 9/4/2024 3:24:23 PM
Kilo Lima - 9/4/2024 3:29:12 PM
moefly - 9/22/2024 4:55:46 PM
tobi - 10/11/2024 5:18:54 AM
norland - 10/12/2024 2:33:33 PM
tobi - 10/13/2024 9:39:28 AM
                         I think the confusion stems from the fact that the bluetooth module is...
Lidders - 11/27/2024 8:16:33 PM
moefly - 2/10/2025 10:10:15 AM
     Nicely done!
Tim Dawson - 9/24/2024 10:16:43 AM
vikino - 9/24/2024 5:35:42 PM
vikino - 3/5/2025 6:56:59 PM
Tim Dawson - 9/25/2024 10:23:55 AM
Kilo Lima - 9/25/2024 7:44:55 PM
Tim Dawson - 9/26/2024 9:51:37 AM
             Thank you Tim.
Kilo Lima - 9/27/2024 10:12:51 PM
AlexLFDP - 10/3/2024 7:02:09 AM
vikino - 10/14/2024 4:20:31 PM
zooyork - 10/13/2024 7:33:14 PM
zooyork - 10/14/2024 9:19:55 AM
Tim Dawson - 10/18/2024 8:42:53 AM
Laycom - 11/4/2024 10:08:30 PM
Laycom - 11/16/2024 6:03:54 PM
Laycom - 12/15/2024 7:38:39 PM
                         Michael, this looks like a perfect solution! Great! You fixed the...
ALSL-Flyer - 12/15/2024 8:50:32 PM
                             Amphenol Conec165X11299XE You will need the slider, the spring and 4...
Laycom - 12/15/2024 9:16:39 PM
                                 Michael, thanks a lot, especially that you forwarded the exact type...
ALSL-Flyer - 12/16/2024 9:56:53 PM
                     An addendum to the Becker AR620X BLE circuit: Do not use...
Laycom - 12/19/2024 9:11:13 PM
Gaznel - 10/28/2024 8:33:43 AM
Tim Dawson - 10/29/2024 10:16:30 AM
Gaznel - 10/30/2024 6:42:03 AM
norland - 11/18/2024 1:47:09 PM
flying_john - 11/18/2024 6:29:58 PM
Laycom - 11/18/2024 8:29:57 PM
Tim Dawson - 11/25/2024 3:51:01 PM
vikino - 11/27/2024 7:35:20 AM
jekroth - 12/6/2024 8:46:26 PM
jekroth - 12/6/2024 8:49:02 PM
SeanKx - 12/5/2024 6:34:49 PM
Laycom - 12/5/2024 9:32:54 PM
Laycom - 12/17/2024 9:32:27 PM
Laycom - 12/18/2024 9:26:38 PM
Paul Milling - 12/18/2024 2:47:54 PM
ALSL-Flyer - 12/18/2024 9:14:28 PM
ALSL-Flyer - 12/19/2024 1:19:41 PM
Dortro - 12/19/2024 9:11:11 PM
Laycom - 12/19/2024 9:34:03 PM
                         Hi Michael,Thank you for your somewhat clinical answer, I appreciate...
Dortro - 12/20/2024 7:28:18 AM
                             Hello Dorto, in addition to my somewhat clinical answer, here are...
Laycom - 12/20/2024 9:43:24 PM
                                 I'm currently thinking about how this could perhaps be done better...
Laycom - 12/20/2024 10:23:28 PM
                                     Hi Michael,Thank you very much for both answers, this is very...
Dortro - 12/21/2024 7:53:40 AM
                                         Dorto, I think 70...90 bugs, like the AR620X BLE. The problem is that...
Laycom - 12/21/2024 10:02:59 AM
                                         Hello dear community, the prototype of a TQ KRT2 BLE PnP (PlugAndPray...
Laycom - 12/22/2024 8:16:04 PM
                                             Super!I am interested and have a KRT2, but…I am in the Netherlands.
Dortro - 12/23/2024 8:01:03 AM
                                             Can’t help with basic testing (I’m UK based), but would be interested...
bsdchapman - 1/4/2025 2:41:07 PM
                                                 Hello Bsdchapman, thanks for your answer. I have now received a KRT2...
Laycom - 1/4/2025 4:36:32 PM
                                                     Hello Michael, very interesting solution. I am using the Krt2 in...
maikmita - 1/6/2025 3:02:49 PM
                                                         Well, the first answer is NO - but it depends... The KRT2 uses an...
Laycom - 1/6/2025 6:58:52 PM
                                                             Michael, thanks a lot for this detailed answer. Right now I do...
maikmita - 1/6/2025 7:34:16 PM
maikmita - 1/6/2025 7:45:19 PM
        I don't see an answer to the problem of a continuously sent status...
Laycom - 1/6/2025 8:16:47 PM
        Hello Maik, some hints from my side. hint1: I have in my plane a KRT2...
ALSL-Flyer - 1/11/2025 2:17:34 PM
        Maik, you got me right. The data from an external source can be...
Laycom - 1/6/2025 7:49:36 PM
                                                     Thanks to bsdchapman, the fleet has received a new member - the...
Laycom - 1/14/2025 10:47:08 PM
SeanKx - 12/20/2024 7:49:00 AM
Final glide - 12/21/2024 9:11:11 AM
Laycom - 12/21/2024 9:18:08 AM
Final glide - 12/21/2024 9:29:34 AM
Laycom - 12/21/2024 9:45:14 AM
                         So for the AV-30 no avlink needed just the data wireI have four data...
Final glide - 12/21/2024 5:55:02 PM
                             Hello Final glide, thank you very much for your post about the AV-30....
ALSL-Flyer - 12/26/2024 1:45:09 PM
                                 Hi ulli It is super simple pins 1,2,and 9 for the av-30 And that’s it...
                                     Thanks a lot... I will check it out. Great hint!!!
ALSL-Flyer - 12/29/2024 2:53:44 PM
                                     Hi Final Glide, we have an installation with one iPad (running SD),...
                                         The software on the standalone version of my BT module supports...
IO390 - 4/20/2025 9:24:32 AM
                                         The data streams must be isolated. The data from the autopilot must...
Laycom - 4/20/2025 12:00:27 PM
                                             Dear Final Glide and dear Michael, thank you for your quick response....
                                                 Stephan, the wait is over. The SD-Link AV-30 adapter is now...
Laycom - 5/6/2025 7:24:41 PM
                             Hi Final Glide. My AV30 is now also receiving the AP-Dataset. Thanks a...
ALSL-Flyer - 1/8/2025 8:10:52 PM
Elric - 12/22/2024 11:10:43 AM
Final glide - 12/22/2024 11:32:31 AM
Bathman - 12/26/2024 9:44:57 AM
norland - 12/26/2024 8:52:41 PM
Laycom - 12/27/2024 8:03:49 PM
Paul Milling - 12/30/2024 4:52:47 PM
urbino - 1/5/2025 8:13:27 PM
Paul Milling - 1/8/2025 1:51:36 PM
ALSL-Flyer - 1/8/2025 8:28:13 PM
ALSL-Flyer - 1/10/2025 8:54:18 PM
Diplomat - 1/18/2025 12:55:32 PM
Laycom - 1/18/2025 1:10:32 PM
Laycom - 1/31/2025 9:15:13 PM
Laycom - 2/1/2025 10:37:14 PM
Bealeyman - 2/12/2025 5:07:57 PM
Bouwair - 2/5/2025 12:46:21 AM
john123 - 2/17/2025 2:18:53 PM
Laycom - 2/20/2025 11:19:57 AM
Clive - 2/20/2025 8:51:32 AM
             Or even a Funke 833
Clive - 2/20/2025 8:56:58 AM
Laycom - 2/20/2025 10:45:10 AM
Clive - 2/20/2025 11:58:11 AM
Clive - 2/20/2025 10:42:52 PM
Petertel - 2/20/2025 1:39:06 PM
Petertel - 2/24/2025 6:27:20 AM
Tim Dawson - 2/20/2025 2:49:12 PM
Petertel - 2/20/2025 3:46:56 PM
SeanKx - 2/21/2025 8:26:02 AM
john123 - 2/21/2025 11:26:41 PM
john123 - 2/23/2025 10:19:04 PM
SeanKx - 2/23/2025 10:25:36 PM
SeanKx - 2/22/2025 8:48:59 PM
bsdchapman - 2/23/2025 10:40:55 PM
Tim Dawson - 2/24/2025 11:49:45 AM
Laycom - 2/24/2025 6:41:11 PM
Petertel - 2/25/2025 10:42:17 AM
Laycom - 2/25/2025 7:10:55 PM
bsdchapman - 2/26/2025 12:27:31 PM
Petertel - 2/25/2025 8:08:25 PM
Petertel - 3/3/2025 7:15:31 AM
Laycom - 3/1/2025 7:54:36 AM
Tim Dawson - 3/10/2025 10:40:19 AM
Mikael Markow - 3/20/2025 9:48:16 PM
Mikael Markow - 3/23/2025 5:10:57 PM
ALSL-Flyer - 3/27/2025 12:57:03 PM
Mikael Markow - 3/27/2025 8:06:03 PM
ALSL-Flyer - 3/27/2025 1:11:25 PM
IO390 - 4/8/2025 11:48:34 AM
fpsrj - 4/15/2025 5:00:03 PM
Laycom - 4/15/2025 5:54:30 PM
Laycom - 4/15/2025 6:59:44 PM
norland - 4/17/2025 6:56:43 PM
norland - 4/20/2025 7:21:39 PM
Tim Dawson - 4/22/2025 9:24:23 AM
norland - 4/23/2025 12:27:10 PM
Bouwair - 4/22/2025 4:45:46 PM
Tim Dawson - 4/24/2025 9:56:22 AM
norland - 6/20/2025 7:11:56 PM
Linoair - 5/14/2025 5:52:59 PM
Laycom - 5/14/2025 7:42:03 PM
Linoair - 5/15/2025 7:08:05 AM
Laycom - 5/24/2025 8:35:03 AM
Mikael Markow - 5/24/2025 2:47:52 PM
Mikael Markow - 6/4/2025 1:40:54 PM
Charly - 6/23/2025 7:53:31 AM
vikino - 8/1/2025 8:46:20 AM
     No, sorry.
Tim Dawson - 8/1/2025 9:55:30 AM
vikino - 8/7/2025 9:36:48 PM
hanysz - 9/18/2025 9:58:37 AM
Mikael Markow - 9/19/2025 8:30:44 AM
Laycom - 9/22/2025 7:15:01 PM
IO390 - 9/23/2025 1:45:17 PM
Laycom - 10/17/2025 10:06:27 PM
