Unhandled exception! SD PC planner not firing up!
duncans
duncans
Posts: 13, Visits: 30
Dear SD Tech Team,
Any help appreciated!
May be completely coincidental but Outlook started to play up at the same time. Mmmm.
System.InvalidOperationException: The specified window is not open.
at TD.SandDock.DockControl.OpenWith(DockControl existingWindow)
at Divelements.SkyDemon.x210ff09a2516b1a7.x80c5917e13d6bc71(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 2.6.2.17135
Win32 Version:
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.Aviation
Assembly Version: 1.0.4857.17133
Win32 Version: 1.0.4857.17133
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
Assembly Version: 3.0.84.2
Win32 Version: 3.0.84.2
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Divelements.Mapping
Assembly Version: 1.0.4857.17132
Win32 Version: 1.0.4857.17132
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
SandBar
Assembly Version: 1.4.3.2
Win32 Version: 1.4.3.2
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
Posts: 593, Visits: 4.9K
I hate to sound like a typical IT helpdesk here but... have you rebooted your machine?
duncans
duncans
Yes, sorry I meant to post my 'actions', but didn't!
Reboot.
Re-install SD
Re-install .net Framework followed by windows update
No joy I am afraid.
In your Documents folder, there is a SkyDemon folder - try moving that folder to your desktop (or somewhere else out of the way), then re-launching.
duncans
duncans
Moving the SD Folder to my desktop forced a new login process, but still gave me the unhandled exception.
I seem to be getting two slightly different exception, this one follows if I select continue, and instead of 'specified window is not open' I get 'object reference not set'.
System.NullReferenceException: Object reference not set to an instance of an object.
at Divelements.SkyDemon.Mapping.xc4c7d023ab77af92.x0d1d644f87ce3440(Object xe0292b9ed559da7d, MouseEventArgs xfbf34718e704c6bc)
at System.Windows.Forms.MouseEventHandler.Invoke(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
at Divelements.SkyDemon.UI.x41964589b3b956a5.OnMouseMove(MouseEventArgs e)
at Divelements.SkyDemon.Mapping.x5cf3c184e49e0afe.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at Divelements.SkyDemon.Mapping.x5cf3c184e49e0afe.WndProc(Message& m)
I can't help any further I'm afraid. Suggest you contact the SD folks directly by phone or e-mail
duncans
duncans
Thanks for trying :-) Over to Tech!
dynaeronaut
dynaeronaut
Too Much Forum (633 reputation)Too Much Forum (633 reputation)Too Much Forum (633 reputation)Too Much Forum (633 reputation)Too Much Forum (633 reputation)Too Much Forum (633 reputation)Too Much Forum (633 reputation)Too Much Forum (633 reputation)Too Much Forum (633 reputation)
Posts: 3, Visits: 15
Same problem here. with winXP updated sky demon and it is broken and has been for over a month.
as far as I can tell this has been a problem since the 19th April update of skydemon, but the older version that works is not available to download. This is a basic coding error in skydemon 2.6.2 and it hasn't been fixed in 2.6.3
really annoying as now my SD mobile is currently useless.
removed reinstalled everything, updated .net and all windows components and still the same problem. It is not the computer it is skydemon code.
dynaeronaut
dynaeronaut
just tried installing 2.3.4 an old version and the problem goes away. it would be sensible if skydemon kept the older versions available for download somewhere so when they break the code in an update users can roll back.
dynaeronaut, did you contact us for support?
