Unhandled exception! SD PC planner not firing up!
duncans
duncans
Posts: 13, Visits: 30
Dear SD Tech Team,
Any help appreciated!
May be completely coincidental but Outlook started to play up at the same time. Mmmm.
System.InvalidOperationException: The specified window is not open.
at TD.SandDock.DockControl.OpenWith(DockControl existingWindow)
at Divelements.SkyDemon.x210ff09a2516b1a7.x80c5917e13d6bc71(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 2.6.2.17135
Win32 Version:
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.Aviation
Assembly Version: 1.0.4857.17133
Win32 Version: 1.0.4857.17133
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
System.Drawing
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
Assembly Version: 3.0.84.2
Win32 Version: 3.0.84.2
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Divelements.Mapping
Assembly Version: 1.0.4857.17132
Win32 Version: 1.0.4857.17132
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
SandBar
Assembly Version: 1.4.3.2
Win32 Version: 1.4.3.2
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
duncans
duncans
Moving the SD Folder to my desktop forced a new login process, but still gave me the unhandled exception.
I seem to be getting two slightly different exception, this one follows if I select continue, and instead of 'specified window is not open' I get 'object reference not set'.
System.NullReferenceException: Object reference not set to an instance of an object.
at Divelements.SkyDemon.Mapping.xc4c7d023ab77af92.x0d1d644f87ce3440(Object xe0292b9ed559da7d, MouseEventArgs xfbf34718e704c6bc)
at System.Windows.Forms.MouseEventHandler.Invoke(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
at Divelements.SkyDemon.UI.x41964589b3b956a5.OnMouseMove(MouseEventArgs e)
at Divelements.SkyDemon.Mapping.x5cf3c184e49e0afe.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at Divelements.SkyDemon.Mapping.x5cf3c184e49e0afe.WndProc(Message& m)
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
Hi
I can't help any further I'm afraid. Suggest you contact the SD folks directly by phone or e-mail
duncans
duncans
Thanks for trying :-) Over to Tech!
duncans - 5/22/2013 5:00:39 PM
stevelup - 5/22/2013 5:04:11 PM
duncans - 5/23/2013 2:09:09 PM
stevelup - 5/23/2013 2:53:51 PM
duncans - 5/23/2013 3:08:39 PM
                         Hi I can't help any further I'm afraid. Suggest you contact the SD...
stevelup - 5/23/2013 3:35:48 PM
duncans - 5/23/2013 4:08:56 PM
dynaeronaut - 5/24/2013 2:49:57 PM
dynaeronaut - 5/24/2013 3:14:48 PM
Tim Dawson - 5/24/2013 3:37:23 PM
dynaeronaut - 5/30/2013 10:47:12 AM
rk19 - 6/3/2013 8:54:58 AM
                     Managed to find an old version. Installed and works fine.
rk19 - 6/4/2013 10:22:09 PM
