Unhandled exception! SD PC planner not firing up!
duncans
duncans
Posts: 13, Visits: 30
Yes, sorry I meant to post my 'actions', but didn't!
Reboot.
Re-install SD
Re-install .net Framework followed by windows update
No joy I am afraid.
stevelup
stevelup
Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)
Group: Moderators
Posts: 593, Visits: 4.9K
I hate to sound like a typical IT helpdesk here but... have you rebooted your machine?
duncans
duncans
Dear SD Tech Team,
Any help appreciated!
May be completely coincidental but Outlook started to play up at the same time. Mmmm.
System.InvalidOperationException: The specified window is not open.
at TD.SandDock.DockControl.OpenWith(DockControl existingWindow)
at Divelements.SkyDemon.x210ff09a2516b1a7.x80c5917e13d6bc71(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 2.6.2.17135
Win32 Version:
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.Aviation
Assembly Version: 1.0.4857.17133
Win32 Version: 1.0.4857.17133
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
System.Drawing
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
Assembly Version: 3.0.84.2
Win32 Version: 3.0.84.2
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Divelements.Mapping
Assembly Version: 1.0.4857.17132
Win32 Version: 1.0.4857.17132
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
SandBar
Assembly Version: 1.4.3.2
Win32 Version: 1.4.3.2
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
