By duncans - 5/22/2013 5:00:39 PM
Dear SD Tech Team,
Any help appreciated!
May be completely coincidental but Outlook started to play up at the same time. Mmmm.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.InvalidOperationException: The specified window is not open. at TD.SandDock.DockControl.OpenWith(DockControl existingWindow) at Divelements.SkyDemon.x210ff09a2516b1a7.x80c5917e13d6bc71(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m) at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- SkyDemon Assembly Version: 2.6.2.17135 Win32 Version: CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe ---------------------------------------- Divelements.Aviation Assembly Version: 1.0.4857.17133 Win32 Version: 1.0.4857.17133 CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- Divelements.SandGrid Assembly Version: 2.2.4.1 Win32 Version: 2.2.4.1 CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- SandDock Assembly Version: 3.0.6.1 Win32 Version: 3.0.6.1 CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL ---------------------------------------- TallComponents.PDF.Rasterizer Assembly Version: 3.0.84.2 Win32 Version: 3.0.84.2 CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/TallComponents.PDF.Rasterizer.DLL ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Divelements.Mapping Assembly Version: 1.0.4857.17132 Win32 Version: 1.0.4857.17132 CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL ---------------------------------------- SandBar Assembly Version: 1.4.3.2 Win32 Version: 1.4.3.2 CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL ----------------------------------------
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
By rk19 - 6/4/2013 10:22:09 PM
Managed to find an old version. Installed and works fine.
