view
Visits: 15
hello all, I've this problem on my 3 android devices (I know of the 2 devices limits, and they are never used at the same time); It's happening when I try to check the charts: the window open, it try to connect to your servers and then that message show up (and I have obviously tried to log out/in more than a couple of times in the last few days, as you can easily check from your logs) - btw, I've just updated a couple of charts on my xp computer with no faults - so, afaik, it seems a problem limited to android - last access: xp _ a couple of minutes ago - second last access: android _ 2015/01/07 11.44.25 - sd 3.2.0.28307 planning only - exp 2015/04/15 - various android 4.something NOT upgraded recently - [also, sorry for the poor text formatting, but it seems I'm unable to have what once was called a carriage return  ]
adhawkins
Visits: 2.5K
My understanding is it's not a limit on the number of simultaneous uses, rather a limit on the number of devices that can be logged in.
So if you start from scratch, log in on device 1, use it and stop, log in on device 2, use it and stop, then when you log in to device 3, it will log device 1 out. The next time you use device 1, you'll have to log in again.
Bit inconvenient (happens to me as I use SD on a number of PCs depending on where I am), but hardly too much effort.
Andy
T67M
Visits: 3.2K
The 2 device rule is a pain sometimes - I have two Android phones and two Android tablets and occasionally get myself into this mess. Annoyingly if I was half-Apple, I could do exactly what I want to - but not if I was fully-Apple. I keep meaning to ask Tim to make it four any-devices rather than 2 Apple plus 2 Android but I never quite get round to it.
Until now! ;-)
view
Visits: 15
first of all, sorry for the poor manners of my first post: no thanks and no salutations; at least I said hello all, so may be there is hope in the end; and as for my "carriage return" problem, a switch from opera to iceweasel took care of that; adhawkins (1/7/2015) My understanding is it's not a limit on the number of simultaneous uses, rather a limit on the number of devices that can be logged in.
Andy
Andy, thanks for your answer; yes, that's exactly how i got it: a login on a new, third, device, force a disconnect on the first one; unfortunately that's not how it works for me: I'm currently logged in with 2 devices, so not even crossing the limit; using one of the two just to check the charts update force that error, so it seems to me it's number independent; hope to have been able to explain myself, despite my bad command of english thanks again ciao marco
Posts: 8.2K,
Visits: 9.7K
When you log in on a third mobile device (iOS or Android) the first one is logged out again. I know it's a pain, but sadly there are a lot of people out there who want to abuse our system by sharing their login details with their friends. This is why we only allow two mobile devices to be logged into our system under the same account at the same time.
view
Visits: 15
First of all, sorry for this late update (btw, barely in sync with tim answer)
in some way unbeknownst to me, I was able yesterday to login and update my charts, so my problem is solved;
thank you all ciao marco
ps: tim, if, for whatever reason, you need my login details for a check, please just let me know
sindza
Visits: 15
I have same problem... can I buy another licence to solve that issue? Is it allowed to buy two license for same username?
PeterGristwood
Visits: 931
Thanks for the reminder, Tim
I've just bought a second Nexus tablet running under 4.4.3, as the one running 5.1 is not behaving well, but (for a short while only) I'm running them in parallel so I can see how the Lollipoo updates affect SD.
Hope that is alright. It isn't something I'll be doing on a long-term basis
Posts: 8.2K,
Visits: 9.7K
Having two mobile devices connected to SkyDemon at once is no problem, it's allowed under our standard personal subscription (as long as it's the named user using it).
oscarbal
Visits: 41
Tim Dawson (1/9/2015) When you log in on a third mobile device (iOS or Android) the first one is logged out again. I know it's a pain, but sadly there are a lot of people out there who want to abuse our system by sharing their login details with their friends. This is why we only allow two mobile devices to be logged into our system under the same account at the same time.Hi Tim, I recognize the fact that people may be sharing their accounts, which is not nice (you have to earn some money as well as a company), but by reducing the number of concurrent mobile devices to 2 max, you get to the point where the 'proper' users start to get hindered. To give you my example: When making a flying trip, I regularly use 1 Nexus 7 mounted in the aircraft for navigation purposes. On the ground I use my iPad (which is too big to use for in the cockpit) to do some preparations for the next leg. I want my iPhone to be standby as backup in case my Nexus stops working. Transferring newly planned routes is becoming a real nightmare now, with logging in every time on each device to get the routes and info updated on all devices. During my trips I am not using my PC-based account at all. I would appreciate to have max limit of 3 or 4 concurrent devices, no matter what, either PC or mobile device. This will still block effectively the 'illegal' users, but will allow the paying customers to use the excellent product you have without too much 'blocking' issues. Can you please reconsider this? Thanks!
