Mikael Markow
M
Posts: 9, Visits: 0
I have made a video to show how to send frequencies from Skydemon to radios via Aviation Companion, and how to connect it:
https://youtu.be/K64hIN3Lyvg
Edited 5/24/2025 2:56:59 PM by Mikael Markow
Mikael Markow
M
Posts: 9, Visits: 0
Now the radio Microair M760Q can be controlled from Skydemon.
It is a 25 kHz radio so only x00, x25, x50, and x75 kHz frequencies can be set.
x05, x30, x55, x80 has the same frequencies as those above and are also transferred to the radio. These have a more narrow bandwidth and are more precise but many people still use 25kHz radios for this.
Set Skydemon to "GTR225" and Aviation Companion to "mode 1".
https://youtu.be/v6jRFcgBPcc
norland
n
Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)
Posts: 12, Visits: 0
Tim Dawson - 4/24/2025 9:56:22 AM
Thanks. Looks like we have already implemented protection against that in the forthcoming 4.1 release.
Can confirm that crash with the AR6201 is indeed fixed in the latest release.
Charly
C
Forum Newbie (3 reputation)Forum Newbie (3 reputation)Forum Newbie (3 reputation)Forum Newbie (3 reputation)Forum Newbie (3 reputation)Forum Newbie (3 reputation)Forum Newbie (3 reputation)Forum Newbie (3 reputation)Forum Newbie (3 reputation)
Posts: 1, Visits: 0
I have just installed the "Dual-Source" type from SDlink on my RV12iS
Happy to have the possibilty to send the frequence from Dynon HDX and/or diriectly from Skydemon.
Its just great and it works perfect!
vikino
v
Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)
Posts: 33, Visits: 85
Hi Tim, it is somehow possible to set default location services device? That you dont need every time to choose BT device...
Vitek
No, sorry.
vikino
v
Tim Dawson - 8/1/2025 9:55:30 AM
No, sorry.
:-( some tick button like "Remember my choice" would be really appreciated... and if connection to BT fails, then ask again to select device...
hanysz
h
Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)Forum Newbie (1 reputation)
Posts: 1, Visits: 0
I am trying to connect my TQ KRT2 radio to SkyDemon using a Bluetooth adapter (this one: https://ogn.ibisek.com/index.php/en/2022/04/20/krt2-bluetooth/).
The adapter is powered and wired to the radio, but SkyDemon on both iPad and Android does not detect any Bluetooth device. I cannot see the adapter in the SkyDemon connectivity menu.
Has anyone successfully used this type of adapter with SkyDemon?
Do I need a special BLE-RS232 module (instead of classic Bluetooth)?
Should the KRT2 display the “r” symbol when connected?
Is there a specific SkyDemon setting I am missing?
Any advice or experience would be very helpful.
Thanks in advance!
Mikael Markow
M
Posts: 9, Visits: 0
hanysz - 9/18/2025 9:58:37 AM
Thanks in advance!
For TQ KRT2 to work with SkyDemon you need a BLE-Bluetooth.
I suggest, for mechanical reasons, to use an adapter with cables to your radios connector and not an "in between plug".
I produce this one:
https://www.utronix.se/Aviation/index.html
I have designed it from the ground, written the firmware, designed the PCB etc. It is designed for harsh environment and is potted with urethane to make it handle the moist and the vibrations in an aircraft. It has large data buffers too.
\Mikael
Michael Hoffmann
Michael Hoffmann
Posts: 48, Visits: 23
Thanks in advance!
Hi Hanysz,
SkyDemon only supports BLE (Bluetooth Low Energy) devices for setting radio frequencies. These devices work without prior configuration in the smartphone's Bluetooth environment (iPhone/iPad and Android). "Regular Bluetooth adapters" for audio/headsets, printers, and other peripherals don't work here. You don't need to configure these adapters in the smartphone's Bluetooth environment— no, you're actually not allowed to. You won't find a device.
Simply go to "Third-Party Devices" in SkyDemon or "Connectivity" in the English version (which is currently inconsistent). Select the adapter you find, assign it a function (radio, autopilot, etc.) and a manufacturer for the protocol, and you're done.
Here's another tip:
To find a BLE adapter on an Android device, not only the "Bluetooth" service but also the "Locator" service must be enabled.
We receive many support requests regarding these settings.
Regarding the specifically requested KRT2 adapter - here is the link:
Cheers,
Michael
