Finger Friendly SIP
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
Hi
As promised, here is the finger friendly input panel I've been working on. It is intended for users of 800x480 devices, and the size has been optimised to work with SkyDemon as far as possible.
The DLL and a copy of regsvrce can be found here
I can't really give any support for installing this at the minute, but the instructions are as follows:-
Copy both files into the Windows folder of your device.
Launch regsvrce.exe
Enter 'skysip.dll' into the box and tap OK
You now need to select the SkyDemon SIP. There are various ways of doing this - you can either do it in control panel, or by tapping the keyboard/pencil icon at the bottom right of the taskbar.
If you don't have access to your desktop, then you won't be able to use this for now.
I am planning in the future to package it up so it will work on devices that don't have access to the Windows CE shell. It shouldn't be an issue to integrate it into MioPocket for those people who are using that.
Please do not pester me about this though. It'll be done when it's done! Alternatively, now I've done the difficult bit, perhaps someone else could package it?
Steve
stevelup
stevelup
Group: Moderators
7" WinCE 5.0 compatible files are here
Regards,
Steve
nje
nje
Posts: 384, Visits: 4.2K
Thanks Steve I'll have go at installing it later
nje
nje
I'm getting nowhere with this at all. I've downloaded the above file. I went to unzip gbresrv file, but had difficulty extracting it to my device because it only shows up as a device and not a drive. I then extracted it to the desktop and from there copied it to the windows folder on my device. I then copied the sip.dll file to the windows folder.  I went to the ce desktop of my device and opened windowns where I found the gbresrv.exe file and clicked on it but I got this message. " Invalid command argument, Use the following syntax gbregsrv.exe dll name [-u] [-s]  -u = unregister, -s =silent mode
It's probably obvious what I'm doing wrong but I can't spot it. Any help appreciated.
stevelup - 5/28/2011 12:43:46 PM
Runways - 5/28/2011 8:32:42 PM
Runways - 5/28/2011 10:13:36 PM
stevelup - 5/28/2011 10:19:50 PM
Runways - 5/28/2011 10:55:13 PM
stevelup - 5/28/2011 11:28:40 PM
Runways - 5/29/2011 12:33:16 AM
Roger.Wilco - 5/29/2011 8:43:16 AM
Max_UK - 5/29/2011 10:24:28 AM
stevelup - 5/29/2011 11:51:27 AM
Max_UK - 5/29/2011 12:22:31 PM
stevelup - 5/29/2011 4:21:48 PM
stevelup - 5/30/2011 10:53:50 AM
Runways - 5/30/2011 2:34:59 PM
stevelup - 5/30/2011 6:24:09 PM
Jakob - 5/30/2011 8:27:29 PM
stevelup - 5/30/2011 9:23:56 PM
pink leader - 5/30/2011 10:53:26 PM
stevelup - 5/30/2011 11:56:20 PM
Runways - 5/31/2011 5:27:29 AM
Runways - 5/31/2011 11:31:55 AM
stevelup - 5/31/2011 12:50:02 PM
pink leader - 5/31/2011 12:46:14 PM
stevelup - 5/31/2011 12:48:16 PM
pink leader - 5/31/2011 2:51:20 PM
Runways - 5/31/2011 4:26:43 PM
Tony - 5/31/2011 6:43:47 PM
Max_UK - 5/31/2011 7:28:30 PM
stevelup - 5/31/2011 10:46:10 PM
pink leader - 5/31/2011 7:29:03 PM
Tony - 5/31/2011 10:07:05 PM
stevelup - 5/31/2011 10:50:43 PM
Jakob - 6/6/2011 7:26:25 PM
Runways - 6/1/2011 7:56:43 AM
stevelup - 6/1/2011 8:06:13 AM
Runways - 6/1/2011 10:38:47 AM
Roger.Wilco - 6/2/2011 1:50:53 PM
stevelup - 6/2/2011 3:03:33 PM
     800x480
Roger.Wilco - 6/2/2011 3:23:08 PM
stevelup - 6/2/2011 4:17:44 PM
stevelup - 6/2/2011 4:19:19 PM
Roger.Wilco - 6/2/2011 5:19:06 PM
Runways - 6/4/2011 5:00:20 PM
stevelup - 6/6/2011 8:02:29 PM
Jakob - 6/6/2011 8:16:59 PM
stevelup - 6/6/2011 9:07:42 PM
screetch82 - 6/12/2011 6:34:28 AM
stevelup - 6/12/2011 9:38:26 AM
Jakob - 6/28/2011 7:09:23 PM
stevelup - 6/29/2011 7:11:15 PM
stevelup - 6/30/2011 9:39:48 AM
stevelup - 7/1/2011 4:09:15 PM
Jakob - 7/3/2011 12:36:56 PM
Max_UK - 7/2/2011 3:55:11 PM
stevelup - 7/2/2011 7:14:54 PM
Runways - 7/2/2011 8:36:15 PM
stevelup - 7/2/2011 10:41:36 PM
KevPilot - 7/4/2011 4:04:33 PM
stevelup - 7/4/2011 6:16:35 PM
stevelup - 7/4/2011 7:04:50 PM
stevelup - 7/4/2011 7:12:22 PM
Richard Avery - 7/8/2011 1:44:42 PM
stevelup - 7/8/2011 2:37:54 PM
Richard Avery - 7/8/2011 3:57:22 PM
Richard Avery - 7/8/2011 4:41:10 PM
nje - 7/8/2011 8:15:55 PM
stevelup - 7/9/2011 8:07:19 AM
nje - 7/9/2011 8:27:00 AM
nje - 7/11/2011 2:44:17 PM
stevelup - 7/11/2011 4:04:08 PM
stevelup - 7/11/2011 5:02:06 PM
nje - 7/11/2011 8:29:44 PM
stevelup - 7/11/2011 9:34:57 PM
nje - 7/12/2011 8:13:53 AM
                 Dispite your good efforts, no success, I've PM'd you
nje - 7/12/2011 7:57:58 PM
nje - 7/13/2011 6:23:29 AM
stevelup - 7/16/2011 3:13:01 PM
Bathman - 7/16/2011 7:02:59 PM
stevelup - 7/16/2011 7:11:37 PM
pink leader - 7/17/2011 8:37:11 AM
stevelup - 7/17/2011 6:25:13 PM
pink leader - 7/18/2011 8:40:30 AM
stevelup - 7/18/2011 11:54:35 AM
Max_UK - 7/18/2011 1:45:12 PM
pink leader - 7/18/2011 9:09:04 PM
stevelup - 7/18/2011 10:10:20 PM
stevelup - 7/19/2011 9:15:30 AM
pink leader - 7/19/2011 10:03:42 AM
stevelup - 7/19/2011 10:51:45 AM
Max_UK - 7/19/2011 10:18:24 AM
pink leader - 7/19/2011 11:12:35 AM
Tony - 7/20/2011 12:45:15 AM
Tony - 7/20/2011 12:48:07 AM
pink leader - 7/20/2011 12:47:46 PM
Tony - 7/21/2011 10:51:00 PM
pink leader - 7/22/2011 1:11:11 PM
stevelup - 7/24/2011 11:30:55 AM
geo586 - 12/16/2011 12:55:21 AM
             stevelup Thanks for trying.:)
geo586 - 12/17/2011 12:45:14 PM
stevelup - 12/17/2011 12:29:03 PM
tikotka - 1/23/2012 8:53:24 AM
stevelup - 1/25/2012 8:16:46 AM
tikotka - 1/25/2012 8:32:32 AM
TLearnC - 9/28/2012 3:49:45 PM
stevelup - 9/29/2012 10:27:32 AM
                         [quote][b]stevelup (29/09/2012)[/b][hr]Unfortunately, the virtual...
TLearnC - 11/6/2012 1:53:29 PM
Hendrik - 8/2/2012 12:48:57 PM
wribeiro72 - 9/8/2012 9:19:39 PM
Runways - 9/9/2012 4:28:58 PM
stevelup - 11/6/2012 4:19:25 PM
