Finger Friendly SIP
Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)
Posts: 593, Visits: 4.9K
Hi folks,
I've re-packaged my original bundle which can be found here.
Extract this zip file (including the folder) to the root of your SD card, then point your navigation link at SkyDemonLaunch.exe.
If you have a device where you need to rename the executable in order to launch SkyDemon, rename both SkyDemonLaunch.exe and SkyDemonLaunch.mscr to the name you need (for example FreedomCE.exe and FreedomCE.mscr), and place them on the root of your SD card along with MortScript.exe.
The files in this archive have been tested on Windows CE 5.0, Windows Mobile 5.0 and Windows CE 6.0.
The script automatically detects your screen resolution, installs and registers the correct SIP, then activates it before finally launching SkyDemon (which it expects to find either in the root of the SD card or in a folder called SkyDemon).
Regards,
Steve
Edited 7/11/2011 5:07:45 PM by stevelup
nje
nje
Posts: 384, Visits: 4.2K
Steve, thanks for all the time and effort you have put into this, but dispite your best efforts on my personal behalf I'm still not getting anywhere. This has nearly become a fulltime issue, I've spent hours on it..
Firstly, I copied all the files you were good enough to put in the nje folder, into the windows folder of my device. I then went into the windows folder on my device and attempted to double click the regdll.exe, but nothing happened. I loaded  (overcopied them)  9 times into the windows folder but no luck. So I then tried your latest all singing and dancing  self automated file.I folowed your instructions and set the navpath to skydemonelaunch.exe and off it went, Skydemon loaded up no trouble, but unfortunately no large keyboard, still the poxy little one. One thing I did notice though, when skydemon started to load something popped up on the screen in the top lefthand corner which I think said something like 'SD SIP enabled'  Thank you very much for your so far, but I think I'll have resign myself to the fact that either me or the device is defective, and I'm not really sure it's the device.
I don't really know why it's not working for you. You're the first person that couldn't get it going.
Do you have access to Control Panel on your device? If so, have a look in the Input Panel section after running my scripts and see if you can see SkyDemon listed in there.
It is much more likely that the problem is with the scripts than the SIP itself. You could try a completely manual install of it:-
1) Copy skysip.dll or skysip480.dll into your windows folder
2) Copy regsrvce.exe from here into your windows folder
3) Browse to your windows folder and double tap regsvrce
4) Click 'browse', then browse to your windows folder and double tap the skysip.dll file
5) You should get a message saying DLL Registration Succeded
6) Go into control panel > input panel (or click the icon at the bottom right by the clock) and see again if you can activate the SkyDemon SIP
If it is the scripts that are broken, and the manual install worked OK, then I'd still like to work out why so I can fix the scripts.
Failing all that, if you want to send me your unit or meet up somewhere, I'm sure we can sort it out.
Edited 7/16/2011 7:11:21 PM by stevelup
nje
nje
Steve, Thanks.
I appreciate your help, I'mgoing flying this morning and will be giving the new beta release a bit of a test so will have a go at your suggestions when I get back in later this afternoon. Thanks for your patience and perserverance
nje
nje
Dispite your good efforts, no success, I've PM'd you
nje
nje
Success at last, and it reallly is an excellent addition to skydemon. I would have liked to have claimed the credit for eventually getting it working on my device but it was all down to Stevelup spending a lot of his time lastnight sorting it out for me. It turned out that I wasn't quite a  dim wit,although not far off, but that my device had some strange peculiaritiies which needed a different approach. It now works perfectly, Thanks Steve, I appreciate your help.
Hi Folks,
Latest version of SkySIP here
New features:-
Single DLL for both 800x480 and 480x272 devices
Supports landscape and portrait orientation and automatically rotates and resizes
Includes a new mini keyboard for 480x272 devices in portrait mode
Compatible with Windows Mobile 5.0, Windows CE 5.0 and Windows CE 6.0
Steve
Bathman
Bathman
Posts: 64, Visits: 247
I can't get the download link for regsrvce.exe to work
I've fixed the link
pink leader
pink leader
Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)
Posts: 519, Visits: 2K
Steve
Sorry to be a bit clueless but there have been many "instructions" for loading this as you have done all the hard work on developing this.
Pl could you give an idiot's guide to installation with the latest package. All I can see is one dll file and am thinking I need to change the names of the .exe and morstcript files  .. but not sure. I have no access to the desktop on my WinCE machine.
Thanks & apologies
