Finger Friendly SIP
stevelup
stevelup
Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)
Group: Moderators
Posts: 593, Visits: 4.9K
By the way, try removing the task bar stuff completely out of the script. SkyDemon tries to take over the screen anyway, and it may be that my task bar stuff is interfering.
I added that for one particular problem device.
Richard Avery
Richard Avery
Posts: 17, Visits: 111
I would love to get this to work on my Mio V735 (running WinCE 6.0), however I cannot register the skysip.dll.
When I manually run regsvrce.exe, nothing happens! Consequently I am unable to load the SIP.
I would be very grateful to hear any ideas people may have to resolve the problem. Are there particular registry entries which are added when registering the .dll? If so, would it be possible to write these entries manually via my script which runs at boot?
Many thanks,
Richard Avery
stevelup
stevelup
Group: Moderators
I've no idea what happens when a DLL is registered to be honest!
Please use this regsvr tool instead. The version you need is the ARMV4i.
It's command line only so you'll either have to do it from a command prompt on your device, or wrap it in a MortScript.
Edited 7/8/2011 7:00:54 PM by stevelup
Richard Avery
Richard Avery
Thanks Steve, that worked like a charm!
Many thanks for your help and well done for creating such a great addition to SkyDemon Mobile.
Richard Avery
Richard Avery
Richard Avery
For those of you who are interested, when using RegServer (gbregsrv.exe), the code required to wrap the process in MortScript is:
RunWait(SipFolder\"gbregsrv.exe", "\Windows\skysip.dll -s")
nje
nje
Posts: 384, Visits: 4.2K
Stevelup- I'm sure you must be getting a bit fed up by now of daft questions, so sorry about this one. I have read all the pages in this post and to be honest have become quite confused. I have a 7 inch chinese no name with winCe 5.  But I still can't work out if the work you have done will suit my device or if it's just for the winCe 6 models, if it is for mine would it be possible for you to point me to the file I should download please?
I do rememer you asking for someone to send you a device with win CE5 on it to try but not sure if you still need one, if you do, then when I've been flying next Tuesday, I'll be happy to send mine
stevelup
stevelup
Group: Moderators
7" WinCE 5.0 compatible files are here
Regards,
Steve
nje
nje
Thanks Steve I'll have go at installing it later
nje
nje
I'm getting nowhere with this at all. I've downloaded the above file. I went to unzip gbresrv file, but had difficulty extracting it to my device because it only shows up as a device and not a drive. I then extracted it to the desktop and from there copied it to the windows folder on my device. I then copied the sip.dll file to the windows folder.  I went to the ce desktop of my device and opened windowns where I found the gbresrv.exe file and clicked on it but I got this message. " Invalid command argument, Use the following syntax gbregsrv.exe dll name [-u] [-s]  -u = unregister, -s =silent mode
It's probably obvious what I'm doing wrong but I can't spot it. Any help appreciated.
stevelup
stevelup
Group: Moderators
gbregsrv is command line only - you can't double click it.
Have a look in the folder and download nje.zip. Empty all the files in that folder into your \Windows folder, then double click regdll.exe on your device.
