Import Custom User Charts
Tim Dawson - 2/9/2021 4:22:29 PM
We have no plans to introduce custom georeferenced charts in SkyDemon. It isn't an often-requested feature, and we judge the complexity it would add to the product to be not worth it.
I am sorry to hear that! It may not have been mentioned often, but it would solve some shortcomings.
If the custom data airfields simply would get a Plate ID to its ICAO code in the Plates index.xml and the possibility to add a PDF with your simple ReferencePoint mechanics it would be all needed - it would be 'just another airfield as any other'. GeoRef'ing in Skydemon does not look particularly complicated on the PC in the end, see the quick GoogleEarth overlay shot below:
(For the PC tinkerer: pull C:\Users\<user>\AppData\Roaming\Divelements Limited\SkyDemon Plan\Plates\index.xml, look for the PlateID of the airfield, understand the georeferencing by the readable definition of the box on the pdf and some reference points, change the <PlateID>.pdf to whatever you want, save. Yes, I know there are some functions to do as well to add custom data this way, but why not add a country = customlands ?)
Edited 2/10/2021 12:09:10 PM by pilot-byom
SkyDemon Team (679K reputation)SkyDemon Team (679K reputation)SkyDemon Team (679K reputation)SkyDemon Team (679K reputation)SkyDemon Team (679K reputation)SkyDemon Team (679K reputation)SkyDemon Team (679K reputation)SkyDemon Team (679K reputation)SkyDemon Team (679K reputation)
Posts: 8.1K, Visits: 9.4K
177
1
Too Much Forum (887 reputation)Too Much Forum (887 reputation)Too Much Forum (887 reputation)Too Much Forum (887 reputation)Too Much Forum (887 reputation)Too Much Forum (887 reputation)Too Much Forum (887 reputation)Too Much Forum (887 reputation)Too Much Forum (887 reputation)
Posts: 72, Visits: 757
Can you make an option to upload georeferenced charts into SD just like in ForeFlight?
