Stratux
EU001939
E
Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)
Posts: 9, Visits: 2
Maybe off topic but has anyone found a working AHRS app for an Ipad that works with your stratux device ?
My Stratux works fine with Skydemon for traffic, but as Skydemon does not have AHRS capability, and Garmin Pilot only works with own devices, I am a bit at a loss on how to set-up my Ipad as a secondary, emergency AHRS.
I know the web UI of stratux works, but it is very basic, and paying 200 $ a year for Foreflight is a waste of money.
Any suggestions ?
Posts: 8.2K, Visits: 9.8K
This forum is for the discussion of SkyDemon issues. Could we keep it that way? Thanks!
TouchTheSky
T
Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)
Posts: 153, Visits: 4.6K
Thanks to neubamat's observations and suggestions, a new Stratux IMG is now available here:
On the settings page there is now a GDL90 MSL Altitude Switch which by default is ON but has to be switched OFF for SkyDemon.
Happy testing.
Edited 9/24/2018 7:39:01 PM by TouchTheSky
ArnaudC
A
Posts: 83, Visits: 137
EU001939 - 9/2/2018 9:02:25 AM
has anyone found a working AHRS app for an Ipad?
A-EFIS
</offtopic>
Rdkraker
R
Posts: 3, Visits: 0
Have build a stratux receiver with dvbt stick and USB GPS dongle. Get location in sd, and traffic on stratux webpage.
However no traffic in sd...
Have set vertical limits for traffic to 40000ft however nothing shows.
Any settings I need to change?
Do I need to switch msl alt off in stratux?
Or do I need a barometric input on de pi? And if so, since I don't need ahrs, is there an USB dongle for that?
Edited 10/5/2018 3:55:42 PM by Rdkraker
TouchTheSky
T
Rdkraker - 10/5/2018 3:52:46 PM
- in SD under Setup>Third-Party Devices> you should select SkyEcho, iLevil
- leave the MSL switch off for SD
- for ADS-B you don't need the AHRS/Baro module
TouchTheSky
T
SemperFi - 10/6/2018 10:01:05 AM
TouchTheSky - 10/5/2018 4:54:33 PM
When I tried, traffic won't show without the Stratux delivering baro information to Skydemon alongside the ADS-B data, has that changed?
You may be right, nothing has changed in that respect. Therefore an AHRS/Baro module is required (and makes sense).
efrenken
efrenken
Posts: 265, Visits: 3.5K
@ArnaudC
Can you please contact me via efrenken[at]me.com? I’ve got a question on A-EFIS, which Tim doesn’t want to be discussed on his forum, which I would like to respect.
Thank you.
Eric
TouchTheSky
T
TouchTheSky - 10/6/2018 10:04:14 AM
Just checked/confirmed it - removed the AHRS/Baro module - no traffic any more on SkyDemon.
Rdkraker
R
Posts: 3, Visits: 0
Alright. See where I can find a module in the Netherlands. Probably eBay or amazon...
