Stratux
Fliy
F
Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)
Posts: 11, Visits: 48
TouchTheSky - 2/11/2022 1:46:51 PM
KeiXiD - 2/11/2022 12:50:55 PM
This setting was at 12500ft so it should display targets.
One more thought: did you try to enable and use "FLARM Devices" Air Avionics AT-1 as the location source? Did you set the Stratux IP to 192.168.1.1?
Mine is set to 192.168.10.1 and Mode-S-Signals doesn't appear on SD and even I cannot connect via Air Avionics AT-1 (only by GDL 90).
Is the reason for this problem the wrong IP address I have chosen?
TouchTheSky
T
Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)
Posts: 153, Visits: 4.6K
Fliy - 10/28/2024 4:39:20 PM
Maybe yes but latest Stratux version supports BLE and works nicely with SkyDemon. No WiFi issues any more...
