Stratux
Antoine
A
Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)
Posts: 3, Visits: 1
I work on Raspberry Pi and ADS-B receivers to feed FR24 and Radarvirtuel and yesterday I discovered the Stratux project. I tested it with Foreflight and could see my local traffics Smile. But I'm flying in Europe and I love SD, is there a way to use Stratux signals with SD ? Or stratux's support can be added in addition of Flarm ?
Regards,
Antoine
TouchTheSky
T
Posts: 153, Visits: 4.6K
I connected via GDL90 because I thought this would be the only option to combine Stratux with SD. Is a FLARM based connection possible as well?
‌Thanks btw. for the link to the thread, I was almost already writing a feature request to cyoung. I understand that there are mixed opinions about such a feature but at least getting a warning about another Mode S target on the same flight level that is coming closer would be helpful.
rg
rg
Posts: 109, Visits: 1.9K
TouchTheSky - 1/10/2018 11:58:03 AM
Its looks to me like someone has created a Flarm based fork of Stratux but I've not tried it. I just use the default build and connect via GDL90 but if mode S range rings were possible it would be a winner.
TouchTheSky
T
rg - 1/10/2018 12:12:11 PM
‌Indeed. I will try the FLARM fork of Stratux soon with my second SDR but this is only for receiving FLARM traffic, right? Isn't it a separate thing based on which protocols (GDL90 or FLARM) to connect with the EFB? The earlier mentioned "flarm-network" fork does no longer exist ...
Edited 1/10/2018 12:26:08 PM by TouchTheSky
techie59
t
Too Much Forum (409 reputation)Too Much Forum (409 reputation)Too Much Forum (409 reputation)Too Much Forum (409 reputation)Too Much Forum (409 reputation)Too Much Forum (409 reputation)Too Much Forum (409 reputation)Too Much Forum (409 reputation)Too Much Forum (409 reputation)
Posts: 16, Visits: 3
TouchTheSky - 1/10/2018 12:26:08 PM
Well done Touchthesky!!
I‌ just finish building my Stratux (after a trip to the US and purchase of the equipment on amazon.com). I get the GPS location but I don't see the traffic on SD even if I see planes on the Stratux app.
What configuration of traffic have you implemented on the SD app? I would like to try myself.
T‌hanks to share your tips.
I‌t will be interesting to know when SD will be able to display an artificial horizon. :-)
E‌tienne‌‌‌
Antoine - 9/1/2016 2:41:23 PM
Sky Painter - 9/1/2016 3:30:16 PM
Antoine - 9/2/2016 6:25:07 AM
Tim Dawson - 9/5/2016 10:29:30 AM
Paul_Sengupta - 12/7/2016 2:55:15 PM
piperpa28 - 1/13/2017 11:43:23 AM
eight10man - 1/27/2017 8:51:35 AM
piperpa28 - 1/27/2017 10:48:19 PM
Paul_Sengupta - 1/29/2017 10:45:28 PM
piperpa28 - 1/30/2017 12:00:31 AM
crablab - 3/31/2017 3:59:23 PM
Paul_Sengupta - 4/15/2017 11:26:45 AM
DavidC - 8/26/2017 6:04:55 PM
ACW20 - 9/15/2017 7:06:54 PM
neubamat - 10/2/2017 4:35:38 PM
Tim Dawson - 10/4/2017 2:48:36 PM
neubamat - 10/4/2017 8:27:16 PM
rg - 10/5/2017 7:42:08 PM
neubamat - 10/6/2017 4:11:06 PM
rg - 10/6/2017 4:15:37 PM
neubamat - 10/6/2017 7:00:56 PM
Telefisch - 10/21/2017 3:53:34 PM
                         Try Setup - Navigation Options - Other Traffic and increase "Show...
neubamat - 10/23/2017 4:44:50 PM
                             I would love if this thread could be kept alive, I'm considering...
Viscab - 10/29/2017 7:31:19 PM
                             Thanks for that Tip, I‌'ll give it a try, next time the weather will...
Telefisch - 10/30/2017 10:12:16 AM
                                 Ok, meanwhile I went flying and was a bit disappointed. I‌ thought,...
Telefisch - 11/7/2017 1:01:45 PM
                                     Have you installed the latest stratux software? And if so have you...
rg - 11/7/2017 1:35:31 PM
                                         Yes, I have installed the MPU9250-BMP280. If Software is at latest...
Telefisch - 11/7/2017 4:42:01 PM
                                         Sorry for coming back to this topic. Can someone confirm that the baro...
TouchTheSky - 4/23/2018 11:34:02 AM
                                             Yes it is.
rg - 4/23/2018 3:28:33 PM
                                                 Is there any particular reason for it?
TouchTheSky - 4/23/2018 4:26:33 PM
                                                     Without it the GDL90 message only includes GPS altitude and Skydemon...
rg - 4/23/2018 4:46:20 PM
                                                         Ok, understood.
TouchTheSky - 4/23/2018 6:17:02 PM
Tim Dawson - 11/8/2017 11:40:15 AM
popov - 11/22/2017 12:27:21 PM
             www.stratux.me
Telefisch - 11/22/2017 12:47:02 PM
TouchTheSky - 1/9/2018 12:04:47 PM
TouchTheSky - 1/10/2018 10:41:26 AM
rg - 1/10/2018 11:19:16 AM
techie59 - 2/13/2018 8:36:31 PM
TouchTheSky - 2/13/2018 9:13:27 PM
techie59 - 2/19/2018 1:01:33 PM
popov - 2/20/2018 9:27:42 AM
popov - 2/27/2018 10:18:55 AM
rg - 2/27/2018 10:22:47 AM
TouchTheSky - 2/27/2018 10:45:06 AM
                         Oh wow! I just thought this was a FLARM connection to SD. I hadn't...
rg - 2/27/2018 11:48:35 AM
TouchTheSky - 2/27/2018 10:48:06 AM
popov - 2/27/2018 10:50:46 AM
                         I replaced it with the following: ‌‌...
TouchTheSky - 2/27/2018 11:34:58 AM
                             Thank you :) T‌his was awesome info!
popov - 2/27/2018 11:43:59 AM
                             According to Dan Murray, the benefit of the ground plane is...
TouchTheSky - 2/28/2018 7:27:36 AM
                                 G‌ot to ask just to be sure as English is not my native language: D‌o...
popov - 2/28/2018 7:33:28 AM
                                     No, the other way round. It is a risk to use the ground plane.
TouchTheSky - 2/28/2018 8:08:07 AM
xls125martins - 5/13/2018 2:24:06 PM
PaulSS - 2/28/2018 10:55:11 AM
TouchTheSky - 2/28/2018 11:25:37 AM
KevinWolters - 3/11/2018 2:05:45 PM
TouchTheSky - 3/11/2018 3:22:33 PM
KevinWolters - 3/11/2018 3:52:27 PM
TouchTheSky - 3/11/2018 4:19:57 PM
                         Today i received my parcel from the USA! :D b‌ut unfortunately i...
KevinWolters - 3/23/2018 10:43:51 PM
                             I am not an antenna expert. I did however use the above 868MHz antenna...
TouchTheSky - 3/24/2018 5:07:37 AM
KevinWolters - 3/24/2018 9:49:06 AM
TouchTheSky - 3/25/2018 7:57:03 AM
rg - 3/25/2018 3:40:29 PM
TouchTheSky - 3/25/2018 5:55:05 PM
                         Ok. Thanks. So unless you know how to reverse it I’ll need another...
rg - 3/25/2018 5:59:44 PM
                             Here is a post with some examples how to program two SDRs. ‌...
TouchTheSky - 3/25/2018 8:31:15 PM
KevinWolters - 3/25/2018 11:27:05 AM
TouchTheSky - 3/25/2018 11:50:04 AM
TouchTheSky - 7/18/2018 8:59:58 AM
xray - 7/29/2018 7:03:53 AM
TouchTheSky - 7/29/2018 9:52:15 AM
xray - 7/29/2018 12:33:27 PM
Tim Dawson - 7/18/2018 10:50:57 AM
TouchTheSky - 7/18/2018 10:55:22 AM
Tim Dawson - 7/18/2018 1:35:21 PM
TouchTheSky - 7/18/2018 1:42:10 PM
TouchTheSky - 7/21/2018 6:40:14 PM
neubamat - 8/21/2018 2:25:28 PM
neubamat - 8/21/2018 3:00:01 PM
             Is there an easy fix available?
TouchTheSky - 8/21/2018 3:06:14 PM
neubamat - 8/21/2018 6:13:27 PM
neubamat - 8/27/2018 8:00:39 AM
TouchTheSky - 8/27/2018 2:34:13 PM
neubamat - 8/27/2018 5:57:37 PM
TouchTheSky - 8/28/2018 6:19:36 AM
TouchTheSky - 8/31/2018 8:33:29 AM
neubamat - 8/31/2018 10:03:39 AM
TouchTheSky - 8/31/2018 10:10:52 AM
neubamat - 8/31/2018 1:18:39 PM
TouchTheSky - 8/31/2018 2:33:28 PM
                 exactly :D
neubamat - 8/31/2018 9:33:31 PM
EU001939 - 9/2/2018 9:02:25 AM
             A-EFIS </offtopic>
ArnaudC - 10/3/2018 3:44:28 PM
efrenken - 10/6/2018 10:14:24 AM
Tim Dawson - 9/3/2018 11:13:16 AM
TouchTheSky - 9/24/2018 7:38:39 PM
on5ap - 3/14/2019 12:37:13 AM
Rdkraker - 10/5/2018 3:52:46 PM
TouchTheSky - 10/5/2018 4:54:33 PM
Rdkraker - 10/6/2018 6:11:44 PM
Rdkraker - 10/15/2018 6:08:21 AM
             Try this:...
TouchTheSky - 10/15/2018 7:57:13 AM
on5ap - 3/18/2019 5:19:37 PM
TouchTheSky - 3/18/2019 5:32:02 PM
on5ap - 3/18/2019 7:26:41 PM
pilot-byom - 6/15/2019 12:03:17 PM
b3nn0 - 6/15/2019 12:41:16 PM
pilot-byom - 6/15/2019 2:00:46 PM
joey - 7/9/2019 1:10:37 PM
b3nn0 - 7/9/2019 1:20:56 PM
joey - 7/9/2019 1:28:30 PM
                         I have not tested it personally, but anything RTL-SDR based should...
b3nn0 - 7/9/2019 4:42:58 PM
mxb - 7/9/2019 5:01:20 PM
joey - 7/9/2019 6:10:56 PM
joey - 7/23/2019 3:54:03 PM
pilot-byom - 7/23/2019 5:04:24 PM
Cloudwalker - 4/11/2020 3:17:33 PM
TouchTheSky - 4/11/2020 3:48:58 PM
pilot-byom - 4/11/2020 4:39:47 PM
TouchTheSky - 4/11/2020 4:44:50 PM
                 Thank you! great start!
Cloudwalker - 4/11/2020 7:00:04 PM
screen - 5/17/2020 5:03:51 PM
             Yes
efrenken - 5/18/2020 2:44:51 AM
joey - 7/23/2020 7:59:58 PM
b3nn0 - 7/24/2020 10:21:43 AM
joey - 7/28/2020 7:26:10 PM
Tim Dawson - 7/30/2020 10:59:25 AM
b3nn0 - 7/30/2020 1:55:01 PM
fzahn - 8/3/2020 4:02:37 PM
b3nn0 - 8/3/2020 4:37:16 PM
Exfirepro - 7/30/2020 2:28:12 PM
Maverix - 8/3/2020 10:53:14 AM
pilot-byom - 9/4/2020 9:55:02 AM
b3nn0 - 9/4/2020 10:19:50 AM
                 Thx!
pilot-byom - 9/4/2020 10:25:07 AM
pilot-byom - 9/5/2020 11:05:24 AM
                         all OGN received protocols will still be green, will be displayed on...
b3nn0 - 9/5/2020 5:41:10 PM
                             Just for information, I derived one possible reason for the Flarm...
pilot-byom - 9/6/2020 7:12:49 AM
pilot-byom - 9/23/2020 1:04:23 PM
b3nn0 - 9/23/2020 3:12:12 PM
pilot-byom - 9/24/2020 1:56:24 PM
pilot-byom - 10/6/2020 11:00:45 AM
177 - 2/8/2021 6:30:20 PM
TouchTheSky - 2/8/2021 6:41:16 PM
177 - 2/8/2021 10:07:50 PM
TouchTheSky - 2/9/2021 6:47:16 AM
erchegyia - 8/30/2021 7:17:19 PM
TouchTheSky - 8/31/2021 7:22:13 AM
erchegyia - 8/31/2021 11:00:32 AM
TouchTheSky - 8/31/2021 12:17:32 PM
Fedko - 10/4/2021 11:14:26 PM
TouchTheSky - 10/5/2021 8:56:17 AM
erchegyia - 10/6/2021 7:45:41 AM
b3nn0 - 10/7/2021 7:26:38 AM
erchegyia - 11/1/2021 11:01:01 AM
177 - 11/1/2021 2:12:46 PM
Fedko - 12/16/2021 8:45:31 PM
TouchTheSky - 12/17/2021 7:02:06 AM
Fedko - 1/15/2022 2:30:20 PM
TouchTheSky - 1/15/2022 4:37:37 PM
                         and to add some advice - the flat area of the pinkish GPS antenna has...
BJS - 1/15/2022 7:25:41 PM
KeiXiD - 2/10/2022 9:48:24 PM
TouchTheSky - 2/11/2022 6:47:58 AM
KeiXiD - 2/11/2022 12:50:55 PM
TouchTheSky - 2/11/2022 1:46:51 PM
                         That's what he stated in the first question. I have the same settings...
erchegyia - 2/11/2022 1:49:24 PM
                             To see Bearingless Targets in SD, you must use the FLARM Protocol....
Exfirepro - 2/12/2022 12:43:55 AM
                             Im pretty sure there were some planes near
KeiXiD - 2/12/2022 1:57:54 AM
                         I use Flarm with AirConnect but do not use the Setting „Air Avionics“...
KeiXiD - 2/12/2022 1:41:35 AM
                         Mine is set to 192.168.10.1 and Mode-S-Signals doesn't appear on SD...
Fliy - 10/28/2024 4:39:20 PM
                             Maybe yes but latest Stratux version supports BLE and works nicely...
TouchTheSky - 10/28/2024 5:27:21 PM
