Stratux
rg
rg
Posts: 109, Visits: 1.9K
neubamat - 10/6/2017 4:11:06 PM
Got my MPU9250+BMP280 module today and connected it to raspberry's GPIO pins. I'm seeing traffic in SD with the latest stratux release... as expected BigGrin
Can you post a link to the module you purchased?
neubamat
n
Too Much Forum (778 reputation)Too Much Forum (778 reputation)Too Much Forum (778 reputation)Too Much Forum (778 reputation)Too Much Forum (778 reputation)Too Much Forum (778 reputation)Too Much Forum (778 reputation)Too Much Forum (778 reputation)Too Much Forum (778 reputation)
Posts: 19, Visits: 18
rg - 10/6/2017 4:15:37 PM
‌Yes, it's a MPU9250 BMP280 10DOF. I bought it from a local/german seller, but the linked one looks exactly like mine.
Mapping to raspberry pins (fsync isn't required/available):
  • ‌3‌V3 ‌- pin 1
  • GND - pin 6
  • S‌CL - pin 5
  • SDA - pin 3
Telefisch
T
Too Much Forum (459 reputation)Too Much Forum (459 reputation)Too Much Forum (459 reputation)Too Much Forum (459 reputation)Too Much Forum (459 reputation)Too Much Forum (459 reputation)Too Much Forum (459 reputation)Too Much Forum (459 reputation)Too Much Forum (459 reputation)
Posts: 6, Visits: 0
Hello, I also tried the MPU9250-BMP280 Module.
On stratux page, I got traffic, GPS and AHRS Data.
In SD I couldn‘t See anything.
Connected via GDL90 and got position from stratux but no traffic.
Under menu traffic, I only have a black background with a thin red cross.
Any ideas?
neubamat
n
Telefisch - 10/21/2017 3:53:34 PM
Any ideas?
Try Setup - Navigation Options - Other Traffic and increase "Show Within Vertically" threshold. SD filters irrelevant traffic to declutter your map.
Viscab
V
Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)
Posts: 1, Visits: 1
I would love if this thread could be kept alive, I'm considering building a stratux with ahrs myself, and would love if it got integrated in to skydemon
Telefisch
T
Posts: 6, Visits: 0
neubamat - 10/23/2017 4:44:50 PM
Thanks for that Tip,
I‌'ll give it a try, next time the weather will let me fly.
Telefisch
T
Posts: 6, Visits: 0
Telefisch - 10/30/2017 10:12:16 AM
Ok, meanwhile I went flying and was a bit disappointed.
I‌ thought, that perhaps I could see Mode-S Transmitters but that was a fault.
E‌ven a SAR-helicopter in AD-Pattern wasn't visible in Stratux / SD so I think it is useless weight here in germany.
rg
rg
Have you installed the latest stratux software? And if so have you got the ahrs chip (which includes the baro sensor)? If no baro sensor you’ll not see traffic in SkyDemon unless you downgrade stratux software to 1.2 but you should see the traffic on the stratux web page.
Telefisch
T
Posts: 6, Visits: 0
Yes, I have installed the MPU9250-BMP280.
If Software is at latest version, I need to check.
But as I know by now, most Transponders do obviously not send position signals.
Sad
If you were expecting an ADS-B receiver to somehow show plain mode C/S data then your expectations were at fault. It'll be better in the future, though - as long as everybody equips with ADS-B out equipment, which is certainly the future of electronic conspicuity.
