Can't connect to PowerFlarm
TouchTheSky
T
Posts: 153, Visits: 4.6K
neubamat - 9/2/2018 7:54:22 PM
I've noticed that SD tries to connect to different IPs and ports depending on the PIN... e.g.:
  • 0000: 192.168.0.14:100
  • 4500: 169.254.1.1:2000
  • 5000: 1.2.3.4:2000
  • 5500: 192.168.1.1:2000
sample netstat output:
Must be to address different HW releases... according to Skee's manual snippet...
See integration manual, there seems to be a indeed connection between HW release and PIN:
B104_integrationmanual.pdf (966 views, 453.00 KB)
neubamat
n
Too Much Forum (734 reputation)Too Much Forum (734 reputation)Too Much Forum (734 reputation)Too Much Forum (734 reputation)Too Much Forum (734 reputation)Too Much Forum (734 reputation)Too Much Forum (734 reputation)Too Much Forum (734 reputation)Too Much Forum (734 reputation)
Posts: 19, Visits: 18
Edited 9/2/2018 8:02:00 PM by neubamat
TouchTheSky
T
The new Air Connect uses protected WiFi and therefore no PIN in the app is required any more. However I am afraid the app needs a random key, e.g. "0000" or any other key. Then it should work.
Skee
S
Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)
Posts: 4, Visits: 0
ok so i found this document and punched in pin code 6074 and it works, totaly unreasonable.
Skee
S
Posts: 4, Visits: 0
SO i connected my brand new Airconnect today, its the new version that does not come with a pin code, so what should i have in the pin code row in SD?
So problem is i cant connect it just chews and gives me error.
where do i start?
Please send us screenshots by email (support at skydemon.aero) so we can accurately judge the actual physical size of the text you have seen.
Paul Mahony
Paul Mahony
Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)
Posts: 39, Visits: 424
Please find enclosed a couple of screenshots of contacts that have shown up on my 10" inch iPad running SD after being detected by my aircraft's PF Core. I'm not sure that they show fine detail but you can probably see that the Flarm contact (a glider) has almost totally illegible distance and height info due to the font size. Similarly, the transponder equipped contact is shown by white ring (I.e it was non- threatening) but agin, the distance info is just too small to be read. If it wasn't for the optional audio licence I have with my PF Core, I probably wouldn't have noticed the Flarm contact.
Is there any way the font size can be made bigger please? If you would like the pics to be sent to you via email, please let me know. Thanks.
Paul
Timbo the Wizard
Timbo the Wizard
Too Much Forum (147 reputation)Too Much Forum (147 reputation)Too Much Forum (147 reputation)Too Much Forum (147 reputation)Too Much Forum (147 reputation)Too Much Forum (147 reputation)Too Much Forum (147 reputation)Too Much Forum (147 reputation)Too Much Forum (147 reputation)
Posts: 1, Visits: 2
I've had a problem getting SD to stay connected to PF for more than a few minutes (between 7 and 20) using a Samsung Galaxy Tab 3 or Tab 4 (Android), but have twice run it for over an hour without problem on an iPad (IOS8). Once the connection goes the only way of resolving the issue is resetting the Wifi. LX Avionics (PF dealer) told me that they've had a problem with PF and Android (something to do with update rate, I think the chap said).
Birdyboy
Birdyboy
Posts: 14, Visits: 66
So I think I have found the issue I was having with PFLARM and SD not connecting. I just hadn't noticed that the butterfly connect code had been reset to the default of 1234 in the s/w update and there was now a new place the code under Setup->Device Connectivity Options...
Silly me, I expect it will work OK now.
Europa farm strip flyer, Bedfordshire, UK
It's purely a software system, and will become used when more hardware ADS/B receivers/transceivers are available over the coming year or two, and are connected to SkyDemon.
