Upgrade from 1.3.1 to 1.3.2
LUFTY
LUFTY
Posts: 15, Visits: 65
Hi TIm
I have done an in place upgrade from 1.3.1 to 1.3.2 and I know get an Unhandled Exception Error when first running the application as follows :-
System.ArgumentException: An item with the same key has already been added.
   at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
   at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
   at Divelements.Aviation.EntityData.Managers.AerodromeManager.EntitiesAdded(IEnumerable`1 entities)
   at Divelements.Mapping.Managers.SpotEntityManager`1.AddRange(IEnumerable`1 entities)
   at Divelements.Mapping.Managers.PackagedSpotEntityManager`1.Add(EntityPackage`1 package)
   at Divelements.Aviation.DataManager.<>c__DisplayClass19.<GenerateAddDataDelegate>b__f(Object , EventArgs )
   at Divelements.Aviation.DataManager.<>c__DisplayClass8.<EnqueueQueue>b__7(Object , EventArgs )
   at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
    Assembly Version: 1.3.2.18776
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
    Assembly Version: 1.0.3838.18774
    Win32 Version: 1.0.3838.18774
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Divelements.SandGrid
    Assembly Version: 2.2.3.1
    Win32 Version: 2.2.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
enabled.
For example:
<configuration>
</configuration>
This running under Windows 7 32 Bit.
Lufty
Can you try running the chart manager from the start menu to first upgrade any charts you have loaded?
derekf
derekf
Posts: 39, Visits: 193
Any plans to get SkyDemon to check for upgrades automatically?
It checks when the chart manager is opened. At some point in the future it'll also check in the background after the software is started.
LUFTY
LUFTY
Hi Tim
I had already upgraded the charts using the Data Manager which worked fine.
By the way if you click the OK button on the SkyDemon warning message you can then click continue on the .net framework error and everything works fine.
Lufty
Hi Lufty
Any chance you can email me the zipped up charts and SkyDemon program files you're using and that give you the error? We haven't heard of anyone else running into it so I'm keen to discover what's wrong with that particular configuration.
Update: this has been narrowed down to an issue with the Italy chart published last week. If you run the chart manager from your start menu, it will automatically update the Italy chart with a corrected version we published this morning, and this will solve the problem.
Thanks for reporting it!
pmh
pmh
Posts: 17, Visits: 43
Got exactly same error for some time.
I was in Poland a few month back and installed some zones and points for that use.
It now found that loading the Polish map will give the same error as you got with the Italian. Propably I named a place that is now already named in the new Polish map.
Removing the polish map removes the error.
If you're getting a conflict because you've created your own custom data for Poland and you have now loaded our own Poland chart, you will need to resolve the conflict yourself by getting rid of your own conflicting Poland data. There really isn't anything we can do to resolve this for you.
pmh
pmh
Thanks for the answer.
It is clear for me the two data sets are in conflict. What kind of name convetion do I need to follow not to have this to happen again? I thought the custom data was given special names to avoid risk of overlap.
