Upgrade from 1.3.1 to 1.3.2
http://forums.skydemon.aero/Topic688.aspx
By LUFTY - 7/5/2010 8:54:38 PM
Hi TIm
I have done an in place upgrade from 1.3.1 to 1.3.2 and I know get an Unhandled Exception Error when first running the application as follows :-
System.ArgumentException: An item with the same key has already been added.
   at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
   at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
   at Divelements.Aviation.EntityData.Managers.AerodromeManager.EntitiesAdded(IEnumerable`1 entities)
   at Divelements.Mapping.Managers.SpotEntityManager`1.AddRange(IEnumerable`1 entities)
   at Divelements.Mapping.Managers.PackagedSpotEntityManager`1.Add(EntityPackage`1 package)
   at Divelements.Aviation.DataManager.<>c__DisplayClass19.<GenerateAddDataDelegate>b__f(Object , EventArgs )
   at Divelements.Aviation.DataManager.<>c__DisplayClass8.<EnqueueQueue>b__7(Object , EventArgs )
   at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
    Assembly Version: 1.3.2.18776
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
    Assembly Version: 1.0.3838.18774
    Win32 Version: 1.0.3838.18774
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Divelements.SandGrid
    Assembly Version: 2.2.3.1
    Win32 Version: 2.2.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
System
System.Drawing
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
enabled.
For example:
<configuration>
</configuration>
This running under Windows 7 32 Bit.
Lufty
By Tim Dawson - 7/20/2010 12:24:40 PM
We already make efforts to ensure that the official data contains entries that are unlikely to conflict with user-supplied data. However I'm sure you'll appreciate that the one item in which we cannot do this is and airport's ICAO identifier.
I must admit I don't understand the problem here; once SkyDemon release full or limited charts for a country, you would therefore no longer need any of your own custom airport data for that country, at least not for the public airports that will be covered by our own data and will include ICAO identifiers.
