Upgrade from 1.3.1 to 1.3.2
The most likely confliction is an ICAO identifier for an airfield, which we require to be unique in all loaded data.
pmh
pmh
Posts: 17, Visits: 43
Have now removed my manually entered ICAO airports. That also removed the conflict.
I tried first to rename the airports, but the software will only accept the ICAO designator - not a C before or anything to separate it.
I have understood that the new version will come with an import function. I plan to import some information but it will be difficult not to end up with some duplicates. Would it not be an idea either to present the duplicate error on activation of the map or to add a letter to all the custom data, so it does not interfere with the Skydemon official data?
We already make efforts to ensure that the official data contains entries that are unlikely to conflict with user-supplied data. However I'm sure you'll appreciate that the one item in which we cannot do this is and airport's ICAO identifier.
I must admit I don't understand the problem here; once SkyDemon release full or limited charts for a country, you would therefore no longer need any of your own custom airport data for that country, at least not for the public airports that will be covered by our own data and will include ICAO identifiers.
