Upgrade from 1.3.1 to 1.3.2
LUFTY
LUFTY
Posts: 15, Visits: 65
Hi TIm
I have done an in place upgrade from 1.3.1 to 1.3.2 and I know get an Unhandled Exception Error when first running the application as follows :-
System.ArgumentException: An item with the same key has already been added.
   at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
   at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
   at Divelements.Aviation.EntityData.Managers.AerodromeManager.EntitiesAdded(IEnumerable`1 entities)
   at Divelements.Mapping.Managers.SpotEntityManager`1.AddRange(IEnumerable`1 entities)
   at Divelements.Mapping.Managers.PackagedSpotEntityManager`1.Add(EntityPackage`1 package)
   at Divelements.Aviation.DataManager.<>c__DisplayClass19.<GenerateAddDataDelegate>b__f(Object , EventArgs )
   at Divelements.Aviation.DataManager.<>c__DisplayClass8.<EnqueueQueue>b__7(Object , EventArgs )
   at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
    Assembly Version: 1.3.2.18776
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
    Assembly Version: 1.0.3838.18774
    Win32 Version: 1.0.3838.18774
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Divelements.SandGrid
    Assembly Version: 2.2.3.1
    Win32 Version: 2.2.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
System
System.Drawing
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
enabled.
For example:
<configuration>
</configuration>
This running under Windows 7 32 Bit.
Lufty
