Visits: 149
OK now that I've finished flying for the day and had a chance to play, I can confirm that if you uninstall your previous version of SkyDemon using the Windows Control Panel and Add and Remove Programs and then re-install Version 2.3.2, then it will work.
During the uninstall, you will not lose any of your previous data.
If you use the automatic update with version 2.3.2 and get an error, then using the 'application' repair or remove option by running the install MSI again will NOT fix the problem. You need to do a complete uninstall from the Windows Control Panel.
Thanks to Tim and everyone else in this forum for their help. Hopefully Tim will get to the bottom of why the automatic update is failing on some Windows devices.
Dom.
