weight&balance
n.eicher
n
Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)Forum Member (34 reputation)
Posts: 2, Visits: 0
I cannot enter anything in the field for the "envelope" !!!
This field is not "activ" ...,  whatever I put in , it does not take it
Waht is wrong ?
Gerhard66
G
Posts: 175, Visits: 358
Could you please provide some additional information:
- what type of PC / iPad / Android tablet?
- OS Revision?
- SD Revision
- Screenshot
Julian81
J
Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)
Posts: 4, Visits: 0
For me the same. See below screenshots. Not in my apple ipad or windows laptop. I cant find the future to add the weight and balance.
Can you assist?
Julian
Julian, on your top screenshot, press where it says Weight under your aircraft.
Julian81
J
Posts: 4, Visits: 0
Tim Dawson - 8/31/2021 12:48:29 PM
Thank you Tim, But I want to see the enveloppe. Were can I see this?
Gerhard66
G
Julian81 - 8/31/2021 1:00:04 PM
The general envelope can be set up and is displayed in the „Edit Aircraft“ submenu.
The flight specific envelope seems to appear only in the briefing pack.
Julian, you see the envelope exactly where I told you. Press the Weight button to be taken to the weight and balance screen where the envelope is shown. Perhaps you need to scroll to see it, if you're on a small screen?
Julian81
J
Posts: 4, Visits: 0
Tim Dawson - 9/2/2021 8:28:11 AM
Sorry, but i added all numbers in the requested fields and as you see on the picture the envelope is empty.
Posts: 659, Visits: 32K
Julian81 - 9/2/2021 8:57:56 AM
I suggest looking at the user manual. Depending on your device’s regional settings, the two coordinates for each of the defining points may need to be separated by a comma ',' not a semicolon ';'
Edited 9/2/2021 4:14:35 PM by grahamb
Gerhard66
G
Hi Julian,
you are editing the general aircraft setup.
The flight specific w&b diagram, based on your general aircraft setup, is located under the Route menu.
Hope this helps.
