weight&balance
Gerhard66
G
Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)
Posts: 173, Visits: 358
Gerhard66 - 9/2/2021 4:02:28 PM
Julian81 - 9/2/2021 8:57:56 AM
Tim Dawson - 9/2/2021 8:28:11 AM
Julian, you see the envelope exactly where I told you. Press the Weight button to be taken to the weight and balance screen where the envelope is shown. Perhaps you need to scroll to see it, if you're on a small screen?
Sorry, but i added all numbers in the requested fields and as you see on the picture the envelope is empty.
Hi Julian,
you are editing the general aircraft setup.
The flight specific w&b diagram, based on your general aircraft setup, is located under the Route menu.
Hope this helps.
Julian81
J
Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)Forum Member (32 reputation)
Posts: 4, Visits: 0
Hi Julian,
Hope this helps.
I have it. Thank you very much!
