weight&balance
http://forums.skydemon.aero/Topic33991.aspx
By n.eicher - 8/27/2021 12:11:37 PM
I cannot enter anything in the field for the "envelope" !!!
This field is not "activ" ...,  whatever I put in , it does not take it
Waht is wrong ?
By Julian81 - 9/2/2021 7:01:33 PM
Gerhard66 - 9/2/2021 4:02:28 PM
Julian81 - 9/2/2021 8:57:56 AM
Tim Dawson - 9/2/2021 8:28:11 AM
Julian, you see the envelope exactly where I told you. Press the Weight button to be taken to the weight and balance screen where the envelope is shown. Perhaps you need to scroll to see it, if you're on a small screen?
Sorry, but i added all numbers in the requested fields and as you see on the picture the envelope is empty.
Hi Julian,
you are editing the general aircraft setup.
The flight specific w&b diagram, based on your general aircraft setup, is located under the Route menu.
Hope this helps.
I have it. Thank you very much!
