What is the percentage of Generl Aviation aircrafts we can see in SkyDemo .
frederic
frederic
Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)
Posts: 49, Visits: 63
Hi evrybody,
I tried to find the answer in the forum, but I have not foud.
Question to those who are equipped with a "traffic and collision avoidance" item, what is the percentage of General Aviation aircrafts in Europe that emit in ADS-B out... and so that we could see with SkyDemon (with Pilotaware for ex.)?
If the percentage is big, then I'll buy a Pilotaware quickly, otherwise it's probably not worth it.
Many thanks for your answers.
pilot-byom
p
Posts: 323, Visits: 388
GA aircraft in Europe ADS-B equipped are only very little numbers and even if they are outfitted the visibility via <censored>tools like Pilotaware is rather low, better than low power transmissions but by no means a replacement for see and avoid.
frederic
frederic
MarkusM - 2/9/2019 12:42:30 PM
Thank your.
Pity! I will still wait before investing in this equipment. In the meantime, I will be broadcasting in ADS-B out since I am equipped with them.
pilot-byom
p
If you want to improve situational awareness by adding information to your cockpit, look at the StrauxFLARM distribution. About $200 will give you ADS-B and FLARM IN. The day we replace eyeball see and avoid by a 99% electronic gadget I am out of flying.
If you wait before investing in ADSB-out equipment (or some other form of EC) then you are really part of the problem you're complaining about.
Edited 2/11/2019 11:13:14 AM by Tim Dawson
Bealeyman
Bealeyman
Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)
Posts: 41, Visits: 103
The Skyecho 2 'what it does' description says that Mode C/S proximity is detected but SD seems not to be supporting this.
What is going on here? It will work with Forflight and Easy VFR I am told, but I know little of that as I am a long time and happy user of SD.
pilot-byom
p
Tim Dawson - 2/11/2019 11:13:00 AM
It is not that easy. There is a reason why the US decided to go on a second frequency for UAT and the UK launched the test bed. My bet, if we all go ADS-B-Out on 1090 and that is the only viable option for flying across Europe now, we see exactly the congestion the US feared.
Bealeyman
Bealeyman
Tim, thanks for your response.
I have been using a Zaon MRX PCAS for six years in a PA28 averaging 100hr per year mostly VFR but with some IMC. This device gives nearest transponder mode C/S within 5nm and +/- 1000 ft but no Azimuth. However  one can keep an eye on range/ALT  changing and figure out the threat. Radar or TCAS has to be interrogating, so the transponders reply and the Zaon device picks this up.
I have found it very useful.  I read all the Airprox reports and time after time they say both aircraft equipped with mode c/s but
nobody was carrying a detector.
Sadly my detector has just gone u/s.
There are  a lot of transponder equipped GA aircraft out there and it immediately feels uncomfortable not to have the device.
SE2+SD with this basic feature would be a very good idea and of course there would be the other traffic warnings from
ADSB and Flarm.
Some might think not having Azimuth is a serious drawback but I bet they have never used a range/ALT device over a
long time as I have.
I trust  you are right about the long term but a SE2 would be ordered tomorrow if you said you would fix my problem and I
would not worry if you were going to collect an extra £ 30 per year from me just for the mode c/s traffic info!
Keep up the good work
pilot-byom
p
Bealeyman - 2/13/2019 8:19:39 PM
ADSB and Flarm.
You could simply replace the Zaon by a Monroy with directional antenna and even ARINC429 if wished, would give the same, but with the same increased uncertainty on distance.
Bealeyman
Bealeyman
MarkusM - 2/14/2019 7:46:31 AM
ADSB and Flarm.
Thanks for the suggestion Markus, but still hoping TD will help out.
