SkyDemon Navigation
What is the percentage of Generl Aviation aircrafts we can see in...
What is the percentage of Generl Aviation aircrafts we can see in SkyDemo .
frederic
frederic
posted 2/9/2019 6:10:51 AM
HOT
Visits: 63
Hi evrybody,
I tried to find the answer in the forum, but I have not foud.
Question to those who are equipped with a "traffic and collision avoidance" item, what is the percentage of General Aviation aircrafts in Europe that emit in ADS-B out... and so that we could see with SkyDemon (with Pilotaware for ex.)?
If the percentage is big, then I'll buy a Pilotaware quickly, otherwise it's probably not worth it.
Many thanks for your answers.
Bealeyman
Bealeyman
posted 2/13/2019 11:28:12 AM
Visits: 103
The Skyecho 2 'what it does' description says that Mode C/S proximity is detected but SD seems not to be supporting this.
What is going on here? It will work with Forflight and Easy VFR I am told, but I know little of that as I am a long time and happy user of SD.
Hi evrybody, I tried to find the answer in the forum, but I have...
frederic
2/9/2019 6:10:51 AM
RE: What is the percentage of Generl Aviation aircrafts we can see in...
2/9/2019 12:42:30 PM
Thank your. Pity! I will still wait before investing in this...
frederic
2/9/2019 8:03:39 PM
fredericSee my posts above. Decided about a month ago to purchase...
Bealeyman
4/1/2019 2:46:00 PM
2/10/2019 8:46:56 AM
2/11/2019 11:13:00 AM
It is not that easy. There is a reason why the US decided to go on a...
2/13/2019 4:02:13 PM
Bealeyman
Bealeyman
2/13/2019 8:19:39 PM
You could simply replace the Zaon by a Monroy with directional antenna...
2/14/2019 7:46:31 AM
Thanks for the suggestion Markus, but still hoping TD will help out.
Bealeyman
2/15/2019 10:55:18 AM
2/15/2019 12:01:20 PM
Bealeyman
2/16/2019 7:56:20 PM
GEAR
2/16/2019 9:13:23 PM
Of course I knew this George but could not understand why SD was not...
Bealeyman
2/17/2019 5:48:55 PM
2/18/2019 10:31:05 AM
I understood the challenge of representing bearingless targets on a...
TimT
3/30/2019 9:06:09 AM
frederic
2/18/2019 9:35:40 PM
Frederic, I have a TT21 and have connected an uncertified GPS mouse...
tnowak
2/19/2019 7:43:45 AM
Is enabling ADS-B out with an uncertified GPS legal? Even if, you are...
2/19/2019 11:38:12 AM
2/19/2019 2:32:06 PM
frederic
2/19/2019 8:21:33 PM
You can easily check whether FR24 receives your position by ADS-B or...
EHOW flyer
3/1/2019 10:03:35 AM
I remember when I switched XPDR, these two wires were 10 cents in...
3/1/2019 10:37:32 AM
Attaching a non-certified position source to an ES transponder has...
3/1/2019 2:36:07 PM
Upgrading to WAAS for the sole reason of ADS-B out just seemed over...
3/8/2019 9:52:56 AM
It won't just be a 'UK special' way after a month or so, as EASA have...
3/8/2019 2:12:03 PM
Thanks for pointing to the upcoming Amendment 3 to CS-STAN, I did miss...
3/9/2019 11:25:29 AM
frederic
3/20/2019 10:25:06 AM
4/1/2019 12:08:54 PM
I have since set-up the PaW Rosetta with SD. Traffic Radar, voice...
TimT
6/17/2019 8:32:13 PM
frederic
4/5/2019 5:14:54 AM
cibble10
5/26/2019 5:05:39 PM
frederic
6/27/2019 8:18:26 AM
tnowak
6/28/2019 6:41:43 AM
