Visits: 18K
In my understanding, each time you tap "create a route", SD erases your present route and all that is associated (weather, NOTAMS, airports) and uses the new departure and arrival airports to create the new route. Once a new route is created, why would you hit "Create route" again?
If you want to create multiple routes with the same departure and arrival airports you should save each different route which will retain the additionnal airports in the list.
