PLOG planning without Wind
Johann
Johann
Too Much Forum (524 reputation)Too Much Forum (524 reputation)Too Much Forum (524 reputation)Too Much Forum (524 reputation)Too Much Forum (524 reputation)Too Much Forum (524 reputation)Too Much Forum (524 reputation)Too Much Forum (524 reputation)Too Much Forum (524 reputation)
Posts: 6, Visits: 21
When I plan a route offline e.g. at an airfield (no network) all the date in the PLOG are prefect for me (IAS TrkT HdgM GS) because they are calculated without WIND PERFECT.
These values are usually my basics for the kneeboard to track the time/distance actual/planned. (no wind)
If i do the same route planning but having a network connection the actual wind is taken intor account and all the values
are based on the actual WIND.
Is there a possibility to change the calculation from values With WIND to values without WIND
at PLOG
with SD 3.0.3 android
regards Johann
Johann
Johann
Does nobuddy has an idea?
Regards Johann
nje
nje
Too Much Forum (45K reputation)Too Much Forum (45K reputation)Too Much Forum (45K reputation)Too Much Forum (45K reputation)Too Much Forum (45K reputation)Too Much Forum (45K reputation)Too Much Forum (45K reputation)Too Much Forum (45K reputation)Too Much Forum (45K reputation)
Posts: 384, Visits: 4.2K
I don't quite follow why you want the no wind option, but that's your choice.
I can't think of any way of achieving what you want other than when doing your planning at an airfield with wifi connections, you could just set your device in the offline mode.
micromike
micromike
Posts: 19, Visits: 1.4K
can you not just turn wind off in mapping at the top ? turns off on mine not sure if it takes it into account when planning when its off
Cheers Mike
Anything i say is my opinion you can take it or leave it
Johann
Johann
Thanks for you idea but none of them will work (may bee)
1. ... you could just set your device in the offline mode. If there was a calculation done online, afterward you switch to offline mode, the calculation with wind will stay, there is no way back
2. ...
an you not just turn wind off in mapping at the top ? Tell me more exact please.
3. The planing without wind is a good thing --> even Skydemon has the same opinion than me.
Proof of authententicity
Go to Sky Demon Plan--> Print center --> Pilot Log --> setting --> Perform wind calculations yes / no perfect.
So the question is, why do I not found this this good function in the SkyDemon for Android ?
Any ideas?
Regards Johann
SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)
Posts: 8.1K, Visits: 9.2K
Weather -> Tools -> Set Enroute Wind Conditions.
In that window, you can set the wind to Zero for all legs if you wish.
micromike
micromike
Doing that on android Tim it just crashes out of sky demon ?
Cheers Mike
Johann
Johann
Dear SkyDemon Team
thanks for the instruction. That´s what I have been looking for ....
BUT the same problem as Junior Member also wrote before this is not working SkyDemon for Android 3.0.3.19499 crashes immediately
touching the Individual Legs or All Legs input field (even with the example 270/16)
Now I know how to do, but now I have the crash
Dear SkyDemon Team any ideas for the reason?
regards Johann
We've just published a beta version of SkyDemon for Android 3.0.4 on to our Android page, this may help. The user interface has been substantially updated.
Johann
Johann
Thank´s SkyDemon team great that´s works perfect.
Super support I will advertise SD to my club member in EDQH
Regards Johann
