SkyDemon Flight Planning
PLOG planning without Wind
Johann
Johann
posted 1/31/2014 2:00:42 PM
HOT
Visits: 21
When I plan a route offline e.g. at an airfield (no network) all the date in the PLOG are prefect for me (IAS TrkT HdgM GS) because they are calculated without WIND PERFECT.
These values are usually my basics for the kneeboard to track the time/distance actual/planned. (no wind)
If i do the same route planning but having a network connection the actual wind is taken intor account and all the values
are based on the actual WIND.
Is there a possibility to change the calculation from values With WIND to values without WIND
at PLOG
with SD 3.0.3 android
regards Johann
posted 2/6/2014 3:41:14 PM
Posts: 7.8K,
Visits: 8.5K
We've just published a beta version of SkyDemon for Android 3.0.4 on to our Android page, this may help. The user interface has been substantially updated.
Johann
Does nobuddy has an idea? Regards Johann
Johann
2/3/2014 11:34:35 AM
can you not just turn wind off in mapping at the top ? turns off on...
micromike
2/3/2014 4:43:02 PM
Thanks for you idea but none of them will work (may bee) 1. ... you...
Johann
2/3/2014 10:12:36 PM
I don't quite follow why you want the no wind option, but that's your...
nje
2/3/2014 4:13:44 PM
Weather -> Tools -> Set Enroute Wind Conditions. In that...
2/4/2014 5:29:57 PM
Doing that on android Tim it just crashes out of sky demon ?
micromike
2/4/2014 7:38:59 PM
Dear SkyDemon Team thanks for the instruction. That´s what I have...
Johann
2/4/2014 11:05:24 PM
We've just published a beta version of SkyDemon for Android 3.0.4 on...
2/6/2014 3:41:14 PM
Thank´s SkyDemon team great that´s works perfect. Super support I...
Johann
2/6/2014 6:09:05 PM
Do we know why SkyDemon has started calculating Planned routes with...
helicop
12/17/2023 4:26:03 PM
Check the date and time of the flight you are planning. It will only...
12/17/2023 6:51:36 PM
Yeah i set it to today but still the weather doesn't pull through into...
helicop
12/18/2023 11:44:53 AM
Can you check you're using the latest version of SkyDemon? If you're...
12/19/2023 10:10:03 AM
