By Johann - 1/31/2014 2:00:42 PM
When I plan a route offline e.g. at an airfield (no network) all the date in the PLOG are prefect for me (IAS TrkT HdgM GS) because they are calculated without WIND PERFECT.
These values are usually my basics for the kneeboard to track the time/distance actual/planned. (no wind)
If i do the same route planning but having a network connection the actual wind is taken intor account and all the values are based on the actual WIND.
Is there a possibility to change the calculation from values With WIND to values without WIND at PLOG with SD 3.0.3 android
regards Johann
By Tim Dawson - 12/19/2023 10:10:03 AM
Can you check you're using the latest version of SkyDemon? If you're still having trouble, give us a call and talk us through the route you're trying so we can try to work out what's going wrong.
