WP names in ICAO flight plans
I am running SD 2.4 on an iPad.
When I plan a route using reporting points on the map I don't see their name in the flight plan but only their coordinates. So, e.g., the waypoint "RADLY" shows only up with coordinates. This is unusual and not very friendly for the folk at ATC. Also, it makes it difficult for me to read the flight plan.
My suggestion: use the waypoint name in the flightplan in place of the coordinates.
Thanks, -- Chris.
SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)
Posts: 8.1K, Visits: 9.5K
What you see is correct. The correct way of reporting an EET at an FIR boundary is the EET/LFRR0123 format. To use the name of an airways reporting point there, or a lat/lon, would be an error.
I do not know what MN1 and MN2 are, but they have no place in a flightplan. The only things that should make up a flightplan route are airways reporting points, radio navaids or lat/lons.
Kerosene
Kerosene
Too Much Forum (959 reputation)Too Much Forum (959 reputation)Too Much Forum (959 reputation)Too Much Forum (959 reputation)Too Much Forum (959 reputation)Too Much Forum (959 reputation)Too Much Forum (959 reputation)Too Much Forum (959 reputation)Too Much Forum (959 reputation)
Posts: 6, Visits: 37
I've had a very similar issue this week, on a flight from LHTL to LJPZ. I've used some visual reporting points as waypoints enroute and at destination, but they didn't show up in the ATC flightplan, just the coordinates, which later raised a complaint by the AIS officer in Portoroz. The border crossing point between Hungary and Slovenia was DIMLO, a visual reporting point for the purpose of border crossing, however shown as coordinates only on the ATC flightplan.
I wonder why it shouldn't be be acceptable to use Visual Reporting Points to describe a VFR routing in the ATC flight plan. They are quite normally accepted when filing by other means, e.g. over the phone.
Kerosene
P.S.: Here's a copy of the flight plan, name and registration blanked:
(FPL-HAXXX-VG
-Y18T/L-V/S
-LHTL0530
-N0121VFR DCT 4702N01801E DCT 4641N01625E DCT 4625N01607E DCT
4614N01536E DCT 4554N01501E DCT 4541N01412E DCT 4533N01353E DCT
-LJPZ0216 LJLJ
-EET/LJLA0104 LHCC0105 LJLA0105 LDZO0116 LJLA0116 RMK/CREATED BY
SKYDEMON RMK/PILOT XXXXXXXXX +XXXXXXXXXX DOF/120815
-E/0420 P/3 R/E S/M J/L D/1 4 C YELLOW A/GREY/RED C/XXXXXXXX)
Addresses: LHTLZTZX LHTLZPZX LHCCZFZX LJPZZTZX LJPZZPZX LJLAZFZX LDZOZFZX
Edited 8/20/2012 6:11:08 PM by Kerosene
CMC
CMC
Posts: 8, Visits: 121
I have the same problem. The inability to fill in plain language names renders the flightplan tool useless to me.
In the Swiss AIP it says: "Geographical location names as given on the aeronautical chart ICAO 1:500 000 2253-B Switzerland are accepted by Swiss ATS units." Skyguide/Austrocontro's Homebreefing accepts these names.
My experience after 20 years of flying in europe is that the usage of geographical names in VFR flightplans for waypoints (when lacking radionavigation aids or airport codes) is the norm and the use of coordinates the exception.
Paul
Tim Dawson (20/08/2012)
Hi Tim, you may be right in that the generated flightplan is syntactically correct. However, I can only confirm the experience of my fellow fliers that a flightplan like the one generated by SD would raise eyebrows with ATC and make them come back and ask me questions. Those border crossing points such as, e.g., GOLVA are specifically for reporting a border crossing and use in flight plans.
MN1 and MN2 are waypoints associated with the airport LJMB and expected to be used when landing at LJMB. They are part of my route and hence also part of the Route description in the flight plan. They do bear some significance because the approach controller at LJMB immediately knows that I will follow a sensible route. If I don't put these in the flight plan I will get them as part of the entry clearance in his airspace.
Either way is OK, but there is a reason that I file them as part of my routing. And if I use them as part of my SD route they show up in the fllightplan anyway. So if they already show up it is very confusing not to have them show up with their names.
Somthing to consider...
Thanks very much for a great product and cheers, -- Chris.
i-vela
i-vela
Too Much Forum (440 reputation)Too Much Forum (440 reputation)Too Much Forum (440 reputation)Too Much Forum (440 reputation)Too Much Forum (440 reputation)Too Much Forum (440 reputation)Too Much Forum (440 reputation)Too Much Forum (440 reputation)Too Much Forum (440 reputation)
Posts: 3, Visits: 35
Yep,
having VFR reporting points in plain text in the self-generated flightplan would be great, as even ATCs in Italy request them to be given with the full name.
Asix
Asix
Too Much Forum (542 reputation)Too Much Forum (542 reputation)Too Much Forum (542 reputation)Too Much Forum (542 reputation)Too Much Forum (542 reputation)Too Much Forum (542 reputation)Too Much Forum (542 reputation)Too Much Forum (542 reputation)Too Much Forum (542 reputation)
Posts: 3, Visits: 25
I don't see the problem here. On the Ipad you can just erase the coordinates and type the name of the reporting point in the Flight Plan.
Regards, Asix
Asix (27/08/2012)
Regards, Asix
Well, of course you can. But must of SD's functionality is geared toward making the life of the pilot easier. So why not here?
Beni
Beni
Posts: 18, Visits: 232
Same opinion here, it would make things easier, the syntax "[waypont name] ([coordinates])" would be awesome.
However, I filed a couple of int flight plans using coordinates, nobody ever complained (didn't try it in Italy though).
milansmid
milansmid
Too Much Forum (7.6K reputation)Too Much Forum (7.6K reputation)Too Much Forum (7.6K reputation)Too Much Forum (7.6K reputation)Too Much Forum (7.6K reputation)Too Much Forum (7.6K reputation)Too Much Forum (7.6K reputation)Too Much Forum (7.6K reputation)Too Much Forum (7.6K reputation)
Posts: 68, Visits: 565
I just want to express my full agreement with the opinion that the auto-generated flight plan should specify also the airports (used as waypoints) and VFR reporting points associated with the airports with their ICAO codes and full names instead of coordinates.
I am re-writing the coordinates in the flight plan to their ICAO equivalents and full names everytime I file a flight plan with SkyDemon and it was always accepted by the controlers with no questions (Luxembourg / Belgium, France, Germany, Spain, Portugal, and Czech Republic).
Thanks for considering this, Tim.
Milan
ckurz7000 - 7/23/2012 11:41:58 AM
Tim Dawson - 7/26/2012 12:42:02 PM
ckurz7000 - 7/30/2012 8:50:13 AM
ckurz7000 - 8/19/2012 9:16:33 PM
Tim Dawson - 8/20/2012 2:54:07 PM
Kerosene - 8/20/2012 3:18:54 PM
CMC - 8/20/2012 5:29:16 PM
ckurz7000 - 8/21/2012 6:43:13 AM
i-vela - 8/26/2012 6:28:52 PM
Asix - 8/27/2012 10:54:20 AM
                         [quote][b]Asix (27/08/2012)[/b][hr]Hi, I don't see the problem here....
ckurz7000 - 8/28/2012 7:08:38 AM
                             [quote] Well, of course you can. But must of SD's functionality is...
Beni - 8/28/2012 8:29:25 AM
                                 Hello, I just want to express my full agreement with the opinion...
milansmid - 8/28/2012 11:07:16 AM
Kerosene - 8/20/2012 6:33:46 PM
Tim Dawson - 8/29/2012 12:32:14 PM
ckurz7000 - 8/29/2012 3:22:54 PM
milansmid - 8/29/2012 10:09:00 PM
0fficer - 8/31/2012 4:45:51 PM
                     That my very well be the case but on vfr flights crossing FIR...
ckurz7000 - 8/31/2012 7:42:06 PM
                         That is probably the previous ATC unit giving your details to the...
0fficer - 8/31/2012 10:53:23 PM
stevelup - 9/3/2012 8:30:29 AM
                         Just a bump up post, really. It would be great to get a yes or no from...
ckurz7000 - 9/5/2012 1:52:04 PM
Tim Dawson - 9/5/2012 4:33:07 PM
ckurz7000 - 9/6/2012 7:33:40 AM
milansmid - 9/7/2012 1:48:52 PM
