Upgrade: Version 2.3.2 - Now just crashes and will not run in Windows XP Pro
Upgrade: Version 2.3.2 - Now just crashes and will not run in Windows...
Domwilko
Domwilko
Posts: 29, Visits: 149
As I was planning on flying tomorrow, this evening I fired up SkyDemon to do some planning.
After starting it up it informed me that there was a newer version available. I was currently running version 2.3.0.
I let the installation complete, which it did normally, however, upon trying to start SkyDemon now, it just crashes with a Windows error "SkyDemon.exe has encountered a problem and needs to close."
I tried to repair the install, but even that failed with an error (it was attempting to read a non-existant temporary file in my install directory).
I resorted to an uninstall of SkyDemon, followed by a complete re-install; however, that hasn't worked either.
All my Microsoft Updates are up-to-date.
Going to try and find my previous version install file and roll-back.
Any ideas what the problem may be Tim?
Cheers,
Dom
pink leader
pink leader
Posts: 518, Visits: 2K
Anyone who is stuck, I have posted some previous SD versions in Dropbox.
Email me at david@prospectmanagement.co.uk and I will invite you. Pease ensure you LEAVE the files there and take a copy -- so others can usae if neeed be.
David
Domwilko
Domwilko
pink leader (23/03/2012)
David
Thanks David!
Just emailed you.
pink leader
pink leader
post your email address or PM it - your email ahs not arrived.
D
Domwilko
Domwilko
PM'd you David.
Thanks.
Domwilko
Domwilko
Domwilko (23/03/2012)
David
Thanks David!
Just emailed you.
Thanks David! You're a life saver!
With your help, I've just rolled back to version 2.3.0.18361 and all is working again!!
Thanks for your help.
Domwilko
Domwilko
Have had a brief email conversation with Tim (thanks Tim for responding on a Friday night!!).
They cannot currently seem to replicate the problem which we are seeing, but they will do some more investigation next week.
In the meantime, he has withdrawn the 2.3.2 download from the website and put version 2.3.0 back up.
B2Spirit
B2Spirit
Posts: 24, Visits: 158
I had the same problem, fixed it by just uninsall SD and reinstall again, works fine now.
Doober2004
Doober2004
Posts: 42, Visits: 256
Same occurred to me but I un-installed and re-installed (SD 2.3.2 on Win 7 laptop) and it worked ok - just going to try it out in the air!! I assumed it was to do with not properly un-installing the previous version???
G-OIBM
G-OIBM
Posts: 71, Visits: 946
Same here - I used Windows uninstall and then re-installed. Now all ok.
Many thanks for the help in this forum though :-)
Hugh
Hugh
G-OIBM
Commander 114
Domwilko
Domwilko
If you do a full uninstall from from the control panel (I think I used the app uninstall previously), does the uninstall delete all your previous flight logs and route data or does it just uninstall the app and leave your data in place?
Don't particularly want to lose my data.
Cheers,
Dom
Domwilko - 3/23/2012 8:37:03 PM
G-OIBM - 3/23/2012 8:56:04 PM
Domwilko - 3/23/2012 8:56:18 PM
G-OIBM - 3/23/2012 9:12:23 PM
Domwilko - 3/23/2012 9:38:10 PM
docimd - 3/23/2012 9:43:16 PM
Domwilko - 3/23/2012 9:49:11 PM
pink leader - 3/23/2012 10:12:30 PM
Domwilko - 3/23/2012 10:16:59 PM
pink leader - 3/23/2012 10:25:43 PM
                     PM'd you David. Thanks.
Domwilko - 3/23/2012 10:41:22 PM
Domwilko - 3/23/2012 10:57:37 PM
                     Have had a brief email conversation with Tim (thanks Tim for...
Domwilko - 3/24/2012 12:04:09 AM
                         I had the same problem, fixed it by just uninsall SD and reinstall...
B2Spirit - 3/24/2012 6:47:00 AM
                             Same occurred to me but I un-installed and re-installed (SD 2.3.2 on...
Doober2004 - 3/24/2012 2:16:56 PM
                                 Same here - I used Windows uninstall and then re-installed. Now all...
G-OIBM - 3/24/2012 5:55:45 PM
                                     If you do a full uninstall from from the control panel (I think I used...
Domwilko - 3/24/2012 6:06:52 PM
srayne - 3/24/2012 6:06:58 PM
Domwilko - 3/24/2012 10:36:30 PM
chriso172 - 3/24/2012 10:35:09 PM
