Upgrade: Version 2.3.2 - Now just crashes and will not run in Windows XP Pro
Upgrade: Version 2.3.2 - Now just crashes and will not run in Windows...
Domwilko
Domwilko
Posts: 29, Visits: 149
As I was planning on flying tomorrow, this evening I fired up SkyDemon to do some planning.
After starting it up it informed me that there was a newer version available. I was currently running version 2.3.0.
I let the installation complete, which it did normally, however, upon trying to start SkyDemon now, it just crashes with a Windows error "SkyDemon.exe has encountered a problem and needs to close."
I tried to repair the install, but even that failed with an error (it was attempting to read a non-existant temporary file in my install directory).
I resorted to an uninstall of SkyDemon, followed by a complete re-install; however, that hasn't worked either.
All my Microsoft Updates are up-to-date.
Going to try and find my previous version install file and roll-back.
Any ideas what the problem may be Tim?
Cheers,
Dom
G-OIBM
G-OIBM
Posts: 71, Visits: 946
I have the same issue - just when I need SkyDemon for my planning for tomorrow (Saturday)!
Hugh
G-OIBM
Commander 114
Domwilko
Domwilko
Does anyone have a copy of the 2.3.0 Install MSI they can post or send to me as I seem to have deleted the one I had and I've now got a non-working SkyDemon. Angry
Thanks.
G-OIBM
G-OIBM
For me too please.
Hugh
G-OIBM
Commander 114
Domwilko
Domwilko
OK - Couldn't seem to attach the debug log as a file, so here is the content of the debug log for Tim:
Begin Exception MissingMethodException at 2012/03/23 19:32:15
Product: SkyDemon Plan
Version: 2.3.2.25893
System.MissingMethodException: Method not found: 'Void TD.SandBar.MenuButtonItem.set_StaysOpen(Boolean)'.
at Divelements.SkyDemon.x210ff09a2516b1a7.x85601834555fb7d5()
at Divelements.SkyDemon.x210ff09a2516b1a7..ctor(x173d7d688a9ab88a environment)
at Divelements.SkyDemon.x867eb3246b182488.xc447809891322395()
End Exception
Begin Exception MissingMethodException at 2012/03/23 19:32:50
End Exception
Begin Exception MissingMethodException at 2012/03/23 19:56:07
End Exception
Begin Exception MissingMethodException at 2012/03/23 19:59:00
End Exception
Begin Exception MissingMethodException at 2012/03/23 20:17:57
End Exception
Begin Exception MissingMethodException at 2012/03/23 20:28:41
End Exception
Begin Exception MissingMethodException at 2012/03/23 20:32:33
End Exception
Begin Exception MissingMethodException at 2012/03/23 20:43:22
End Exception
docimd
docimd
Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)
Posts: 1, Visits: 6
I am afraid the same has just happened to me and I am using Windows 7. Uninstall/Repeair/Reinstall will not get it working again. Now stuck without Skydemon. Please repair ASAP-back to the whizwheel this weekend then :-(
Domwilko
Domwilko
"docimd" and "G-OIBM" - Please can you post the content of your 'debug.log' file found in your ..\SkyDemon\ folder on your pc?
The content of this file may give Tim Dawson an insight to what the problem might be and having the information up front may help expedite a fix.
I've already emailed 'both' email addresses I have for Tim.
Cheers,
Dom.
pink leader
pink leader
Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)
Posts: 519, Visits: 2K
Anyone who is stuck, I have posted some previous SD versions in Dropbox.
Email me at david@prospectmanagement.co.uk and I will invite you. Pease ensure you LEAVE the files there and take a copy -- so others can usae if neeed be.
David
Domwilko
Domwilko
pink leader (23/03/2012)
David
Thanks David!
Just emailed you.
pink leader
pink leader
post your email address or PM it - your email ahs not arrived.
D
