Running Inflight with FSX?
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
Just to confim, you are going into GPS Navigation Options to set the port and baud rate, and not the Device Connectivity Options menu?
pfiquet
pfiquet
Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)
Posts: 5, Visits: 6
Thanks but in the mean time, I have done the following :
-uninstall all concerned components
-update Windows Mobile Device Center
-complete stop and restart computer
-install Simconnect
-reinstall HW Virtual and set up com3 on port 8192
-reinstall Fsx2NW with matching settings
-reinstall Skydemon and set for Skydemon mobile device options
But no change in the result, sorry
Don't worry, be happy.
Edited 8/30/2011 2:24:17 PM by pfiquet
Max_UK
Max_UK
Posts: 66, Visits: 2.9K
pfiquet,
Check all your settings again, specially "Fsx2NMEA settings", & "HW Virtual Serial Port HW-VSP3." The settings must match.
The port number must be the same, I use "8192" as suggested by Colin.
In fact, use his exact settings if possible, makes life easier.Smile
Here is a screen picture, I am connecting thru port 23 com3
My setup also tried to use port 23 & had to be changed to 8192.
Regards,
Max.
pfiquet
pfiquet
Posts: 5, Visits: 6
Yes sir
Edited 8/30/2011 9:18:46 AM by pfiquet
stevelup
stevelup
Group: Moderators
SD cannot work out your speed or heading if you're stationary - have you tried actually flying the sim?
pfiquet
pfiquet
Posts: 5, Visits: 6
Hello there,
I just found about Skydemon two days ago on my favorites air stuffs forum www.pilotes-prives.fr.
I don't fly myself but on FSX and therefore, I search for the possibilities to use both together, and thanks to Colin's wonderful work, here I am.
It took me some trials to understand how the interfaces played and now, it seems that my setup is correct, except that in GPS mode,I don't get the flight parameters on the SD map.
Went in the setup mode, tried each one of the three devices options, no changes.
What did I miss.
col-lucy
col-lucy
Posts: 18, Visits: 166
No problem Max. Glad it worked. Let me know if you encounter any problems with it. Incidentally, in FSX Settings/General, there is an option to Pause on Task Switch. If you uncheck it, FSX will keep running when you move to Skydemon.
All the best
Colin
Max_UK
Max_UK
col-lucy,
Wow, just had a very quick "play" & everything works just as you said it would.
Made a slip up initially as the port No.reverted to "23" Deleted the port & created again as port No. "8192".
Lo & behold, there was SkyDemon showing a Cessna 172 being flown on FSX.
Will have more time to experiment during the week, & want to figure out a way to stop FSX pausing every time I adjust SkyDemon Smile
So many thanks Colin, & I'm sure others will also want to give this a try.
Regards,
Max.
col-lucy
col-lucy
Hi Max,
I have posted the program installer here
https://skydrive.live.com/?cid=062a857fb93775aa#!/?cid=062a857fb93775aa&sc=documents&uc=2&id=62A857FB93775AA%211701
and also a document with notes. I recommend you read the document first, because you will need another bit of software too.
You are the first aside from me to try this, so let me know how you get on!
Colin
Max_UK
Max_UK
col-lucy,
This could be of interest to many. If you care to give or upload the details, I would certainly like to try it out.
Recently reloaded FSX & missed SkyDemon's charts. Surprising how soon you get used to things. Smile
Regards,
Max
