Running Inflight with FSX?
pfiquet
pfiquet
Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)Too Much Forum (701 reputation)
Posts: 5, Visits: 6
Thanks but in the mean time, I have done the following :
-uninstall all concerned components
-update Windows Mobile Device Center
-complete stop and restart computer
-install Simconnect
-reinstall HW Virtual and set up com3 on port 8192
-reinstall Fsx2NW with matching settings
-reinstall Skydemon and set for Skydemon mobile device options
But no change in the result, sorry
Don't worry, be happy.
Edited 8/30/2011 2:24:17 PM by pfiquet
Posts: 593, Visits: 4.9K
Just to confim, you are going into GPS Navigation Options to set the port and baud rate, and not the Device Connectivity Options menu?
pfiquet
pfiquet
Posts: 5, Visits: 6
Here are the screenshots of my settings :
"GPS navigation otions" : Port COM3 Baud 9600
"Device connectivity options" = I have a Skydemon mobile device
Max_UK
Max_UK
Posts: 66, Visits: 2.9K
OK, have spotted an anomaly.
I deliberately re-set my Com ports to match yours, "COM3" & everything worked. Only difference I can see is that you have in Fsx 2NMEA "centre box, IP Address"  "127.0.0.1" I have "0.0.0.0"
Worth a try?
Regards,
Max.
Edited 8/30/2011 7:24:33 PM by Max_UK
col-lucy
col-lucy
Posts: 18, Visits: 166
Hi all,
Yes, I am pretty certain the problem is with the Virtual Serial port setup. The port numbers sound wrong. Fsx2NMEA is connected to a TCP socket, but the data must be getting lost at the serial port. I have put a document on my Skydrive with screenshots that show all the serial port settings of Fsx2NMEA, HW Virtual Serial Port & Skydemon Plan. If necessary, delete your serial port config & set up again.
https://skydrive.live.com/?cid=062a857fb93775aa#cid=062A857FB93775AA&id=62A857FB93775AA%211701
Hope that works.
pfiquet
pfiquet
Posts: 5, Visits: 6
Thanks fellows, but I must be a poor geek, HW does not work any more on my PC.
When I solve that problem, I will be back with you to let you know.
Thanks again.
schweboo
schweboo
Posts: 21, Visits: 71
Many thanks for posting this tool - which I have installed successfully and found it to be very helpful/useful.
I have noticed one issue - that when I start up the GPS it tells me that I only have 30 mins as I am using it on a Trial basis. I have a Skydemon GPS - which comes with the Navigation software and a software key that activates the software.
Have I missed something - how do you stop it from shutting down the "virtual" GPS after 30 minutes?
Kind regards
Chris
nickw
nickw
Posts: 10, Visits: 25
Cant realy see why you want to use this on a flight simulator - its for pilots so go fly the real plane. It's much more fun!
Have used already to go to France and it works a treat. Rather do that than lurk in my study with a PC and a virtual plane.
schweboo
schweboo
Me too - but also like to train when the weather is bad
schweboo
schweboo
Also, the CAA have grounded me on medical grounds - at least for the moment...hoping it is only a tempoary problem...but these things always take time to sort out
