Running Inflight with FSX?
http://forums.skydemon.aero/Topic414.aspx
By JohanSvanberg - 2/20/2010 11:00:16 AM
Hi All!
Anyone knows if it's possible to run Inflight connected to the computer and get gps data from FSX?
Thanks!
/Johan
By TheDaniel - 2/2/2014 7:29:58 PM
col-lucy (30/08/2011)
Hi all,Yes, I am pretty certain the problem is with the Virtual Serial port setup. The port numbers sound wrong. Fsx2NMEA is connected to a TCP socket, but the data must be getting lost at the serial port. I have put a document on my Skydrive with screenshots that show all the serial port settings of Fsx2NMEA, HW Virtual Serial Port & Skydemon Plan. If necessary, delete your serial port config & set up again.
https://skydrive.live.com/?cid=062a857fb93775aa#cid=062A857FB93775AA&id=62A857FB93775AA%211701
Hope that works.
Hi, would it be possible to make that file available again? Skydrive tells me its gone (and it's been a while since that post)
Thanks,
Daniel
