iOS terrain map & overlays not or sluggishly updating.
Yes, our new version will be out in 2 weeks which solves the problem.
ardix
a
Too Much Forum (353 reputation)Too Much Forum (353 reputation)Too Much Forum (353 reputation)Too Much Forum (353 reputation)Too Much Forum (353 reputation)Too Much Forum (353 reputation)Too Much Forum (353 reputation)Too Much Forum (353 reputation)Too Much Forum (353 reputation)
Posts: 19, Visits: 24
I can confirm that disabling the breadcrumbs solved the lagging problem, especially with the "colour hight terrain" option active!
My device: iPad mini 6 (iPadOS 18.3.2)
Are you working on a solution to mitigate this "bug"?
I've done some work with ThePhantom to try to identify the cause of what is happening for him. We have found that disabling the in-flight breadcrumb trail makes the problem go away. Could you try that? Once you're in navigation mode, open the main menu, choose Setup, then you'll see the option.
BartH
B
Too Much Forum (88 reputation)Too Much Forum (88 reputation)Too Much Forum (88 reputation)Too Much Forum (88 reputation)Too Much Forum (88 reputation)Too Much Forum (88 reputation)Too Much Forum (88 reputation)Too Much Forum (88 reputation)Too Much Forum (88 reputation)
Posts: 11, Visits: 26
I also had a problem with my iPad Mini 4 since last season. It was overheating more than it did in the past (previously if did only on very hot days). Also had problems with displaying chart tiles - not loading up seamlessly - like in the other guys descriptions. Also the battery life dropped drastically. I thought it was just a problem with the age of my iPad, just coming to the end of its life, but reading now, that guys have similar problems with newer ones (like mini 7) that I was planning to buy I will wait with that.
ThePhantom79
T
Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)Too Much Forum (83 reputation)
Posts: 14, Visits: 28
Today I had a flight, and the IPad (mini 7)  got so hot, that the screen brightness was automaticly adjusted to the minumum. So Skydemon is useless for me. I send an Email to the Skydemon and request to open a ticket - as I think this is a critical bug ...
If more people have this problem as well - please post it here.
ThePhantom79
T
Same problem here ... with brand new Ipad Mini 7 (see my post http://forums.skydemon.aero/Topic37906.aspx )
Slow terrain, warm battery, terrible battery time !
Edited 3/6/2025 9:28:43 PM by ThePhantom79
Joachim Gothe
Joachim Gothe
Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)
Posts: 19, Visits: 58
Tim Dawson - 10/17/2024 9:52:08 AM
What if you created a circular flight, then "flew" it in the SkyDemon simulate mode for an hour, does the problem reproduce then?
Last Thursday after a 10 minute flight from EDVI to EDVM. Protokol on AT1 GDL90, on Skydemon AT1. 9 Seconds between both pictures. Total time of the dropout more than 20 seconds
Achim
Edited 10/26/2024 9:38:55 PM by Joachim Gothe
Joachim Gothe
Joachim Gothe
Tim Dawson - 10/15/2024 2:13:56 PM
Hello Achim, can you reproduce the problem in simulate mode?
No, It usually occurs after a long flight of more than an hour. The iPad mini 6 is very warm and WiFi and Blutooth is on.
I can reprocuce it, when I fly with the MSFS2020 Simulator and WiFi connection with "xmapsy" and GDL90 protocol.
In real Live I fly Air avionics AT1 with AT1 protocol.
Achim
