SkyDemon Navigation
iOS terrain map & overlays not or sluggishly updating.
Prev
1
2
Jump To Page
BenjaminT
B
BenjaminT
posted 10/1/2024 7:27:54 AM
B
Visits: 0
Thanks for following up, Tim.
I've run an extended simulation session and cannot reproduce it simulate mode.
However I've placed the iPad on the co-drivers seat in the car. The problem will reliably occur within 11 to 14 minutes.
posted 9/30/2024 12:13:13 PM
Posts: 8.1K,
Visits: 9.3K
This isn't the first we've heard of somebody experiencing this, but we haven't managed to reproduce it to figure out what's going on. It tends to be happening on older devices, as far as we can tell.
It would be good to know if you can reproduce the issue in simulate mode. Note that if it takes a while for the issue to surface in normal flight mode, it may also take a while to surface in simulate mode.
BenjaminT
B
BenjaminT
posted 9/30/2024 11:17:42 AM
HOT
B
Visits: 0
Hi there,
since this season I'm experiencing major problems with the terrain map and airport overlays.
I'm currently running version 4.0.0.397 on iPad mini 4 running iOS 15.8.3.
All is good in ground mode.
However in flight mode, terrain either won't update at all. Or it updates very sluggishly only some of the tiles. Attached you will find two screenshots from yesterday. They are taken 10s apart.
What sometimes does help (but not always): Running the app in the background and when you switch back to it, it will magically update everything.
Terrain maps might not seem a big issue, however I was experiencing this also with the approach and departure routes e.g. at LOIR.
Is this known to you? Any suggestions?
Benjamin
Prev
1
2
Jump To Page
