Pseudo ILS
Tim Dawson - 2/5/2021 10:09:50 AM
Why not post back here whatever you discover?
Didn't I just write that?
Sorry, to repeat myself, where do I find the threshold location data for a specific airfield? I know where to look at the custom data airfields, but did not find the data for the Skydemon fields at first search. The airfield tab approach information only shows the AIP coordinates.
Edited 2/7/2021 10:44:23 AM by pilot-byom
Threshold coordinates are not viewable in text format inside SkyDemon itself.
Jockflyer
J
Posts: 2, Visits: 0
Anyone using pseudo ILS is already pushing the boundaries of what Skydemon is intended for !!!!    If you need to shoot an ILS you should be using the instruments calibrated in the instrument panel ( assuming you are IR/IMC rated. )
Jock sub 70
efrenken
efrenken
Posts: 265, Visits: 3.5K
pilot-byom - 2/5/2021 8:25:12 AM
grahamb - 2/4/2021 9:15:33 AM
In the AIP. Depending on the country concerned the may be shown on the aerodrome chart, but certainly should be in the text section.
I am absolutely aware of the paper world. My question was regarding the data in Skydemon, where to find that data to see why it is not working as intended. I will check with my custom airfields on the next trip anyway and expect, following Tim Dawsons comment, that it pulls my threshold data from the custom data editor. If not, I'll be back for sure.
What did you find out?
