SkyDemon Flight Planning
Import of GPX
Import of GPX
Prev
1
2
Jump To Page
Import of GPX
posted 8/18/2010 6:14:16 PM
Posts: 8.2K,
Visits: 9.7K
This question was not about importing a route plan, it was about importing a flight log. Tools -> Import Flight Log -> From File.
malcolm frost
malcolm frost
posted 8/21/2010 7:28:11 PM
Visits: 75
You need Tools/Import Flight Log/From File
HTH
The Westmorland Flyer
posted 7/5/2011 10:39:02 AM
Visits: 106
Resurrecting a truly ancient thread...
I can't seem to open/import GPX files into SD 2.1.2.19729. There appear to be two ways to open GPX and neither are working for me:
1. Click on Open and select GPX file type
2. Click on Analysis | Import log from file.
Option 1 says "The file could not be loaded", whilst Option 2 just does nothing at all.
The GPX file origin is GPSMap 296 > Mapsource 6.13.7 > SD
I know I can import track data directly from the 296 but SD provides no way to select individual tracks, so all I see is a mess of all the flights I've done since I last deleted the track memory in the 296.
If SD could let me select individual tracks or alternatively import the GPX file then that would be a big improvement. I can send a sample GPX file if required.
John
G-JONL - Sportcruiser
Diary of a Sportcruiser kit aircraft builder
posted 7/6/2011 12:24:37 PM
Posts: 8.2K,
Visits: 9.7K
Sending us the GPX file in question would help. Both the original from the Garmin, and also the one exported from MapSource.
IkarusC42
IkarusC42
posted 10/22/2011 12:58:40 AM
Visits: 82
Did you cure this? I'm trying to import a .gpx file (converted from .gdb file in Mapsource) of microlight fields into SD but jus get "File could not be loaded" error. File attached. All help gratefully received!
Ikarus
G-TIFG
microlightsites.gpx
800 views,
40.00 KB
Admin
Admin
posted 10/25/2011 1:56:22 PM
Group: Administrators
Visits: 212
Importing a list of waypoints is different. Click on Waypoints, then Import. The file you posted here appears to import just fine.
IkarusC42
IkarusC42
posted 11/3/2011 6:15:20 PM
Visits: 82
Excellent, that worked a treat! Thanks for the help
Ikarus
G-TIFG
Prev
1
2
Jump To Page
