Import of GPX
malcolm frost
malcolm frost
Posts: 21, Visits: 75
Hi all
I flew the other day with a GPS logger which has produced a GPX file of the flight.
What I would like to do is import this into Plan to view it.
I have tried Route/Import/From file and Tools/Open Flight Log and Tools/import from Garmin device with a GPS connected but with no success. I also tried putting the GPX file into the Logs folder and renaming it with a .flightlog extension. Still no luck!
Any ideas?
Thanks.
Hi Malcolm,
SkyDemon doesn't currently support importing a flight log from a GPX file, but if you'd like to attach it here, we'll get the facility added for the forthcoming 1.4 release.
malcolm frost
malcolm frost
Hi Tim
Thanks very much, that explains it!
I've uploaded it as a CSV file as the forum won't accept GPX attachments.
Hope that works OK.
Flight.csv (702 views, 117.00 KB)
Admin
Admin
Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)
Group: Administrators
Posts: 48, Visits: 212
Well, we need it as a GPX file if the goal is to implement importing of GPX files.
I've changed a setting on the forum so that GPX file upload should be allowed.
malcolm frost
malcolm frost
Here you go then!
Flight.gpx (726 views, 297.00 KB)
Thanks. I can confirm that flight log import from GPX file is now supported and you'll see this feature in the next beta drop of the forthcoming 1.4 version.
malcolm frost
malcolm frost
Thanks Tim!
malcolm frost
malcolm frost
Tim
Just to let you know that it works brilliantly on the new Beta, but i guess you already know that!
Thanks for confirming.
pink leader
pink leader
Posts: 518, Visits: 2K
GPX
Downloaded the GPX file and tried importing into SD. Did not work. Works OK with Mem Map. Even tried exporting from MM and then importing to SD.
What am I doing wrong?
Method was Route/Import
Returned an error.
D
