Import of GPX
malcolm frost
malcolm frost
Posts: 21, Visits: 75
Hi all
I flew the other day with a GPS logger which has produced a GPX file of the flight.
What I would like to do is import this into Plan to view it.
I have tried Route/Import/From file and Tools/Open Flight Log and Tools/import from Garmin device with a GPS connected but with no success. I also tried putting the GPX file into the Logs folder and renaming it with a .flightlog extension. Still no luck!
Any ideas?
Thanks.
IkarusC42
IkarusC42
Posts: 8, Visits: 82
Did you cure this? I'm trying to import a .gpx file (converted from .gdb file in Mapsource) of microlight fields into SD but jus get "File could not be loaded" error. File attached. All help gratefully received!
Ikarus
G-TIFG
microlightsites.gpx (799 views, 40.00 KB)
malcolm frost - 8/13/2010 3:01:41 PM
Tim Dawson - 8/13/2010 3:26:32 PM
malcolm frost - 8/13/2010 3:52:37 PM
Admin - 8/13/2010 9:05:54 PM
             Here you go then!
malcolm frost - 8/14/2010 9:48:24 AM
Tim Dawson - 8/14/2010 4:39:01 PM
     Thanks Tim!
malcolm frost - 8/16/2010 5:22:14 PM
malcolm frost - 8/17/2010 7:43:06 PM
Tim Dawson - 8/17/2010 7:57:46 PM
pink leader - 8/18/2010 9:31:53 AM
malcolm frost - 8/21/2010 7:28:11 PM
Tim Dawson - 8/18/2010 6:14:16 PM
The Westmorland Flyer - 7/5/2011 10:39:02 AM
Tim Dawson - 7/6/2011 12:24:37 PM
IkarusC42 - 10/22/2011 12:58:40 AM
Admin - 10/25/2011 1:56:22 PM
IkarusC42 - 11/3/2011 6:15:20 PM
