Editing Log File
Massimo Belloni
Massimo Belloni
Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)
Posts: 35, Visits: 6.5K
Something similar: I just had an overheat problem with my iPad,and it turned off. Luckily I had onboard a backup one, so I was able to continue without problem turning it on..
Of course this generated two different logfiles entry (with few minutes of gap among them).
So, at home, I merged the two logs and obtained a good track (except for the few minutes gap, but that's not a problem).
The issue is that this flight track entry (obtained merging the two partial logs) is ignored by the new logbook selection of logs to be added to the logbook.
Is this caused by a bug somewhere or a behavior by design?
massimo
Massimo Belloni
Try deleting the original two logs, if you're happy with your new log. SkyDemon may not be noticing the new one if it identifies itself with the same takeoff position and place as the original "start" log.
Frédéric SAUVAGE
Frédéric SAUVAGE
Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)
Posts: 7, Visits: 32
SaschaMarc - 9/18/2020 3:58:49 PM
What would be good though, would be being able to edit the plane type/registration and the PIC.
The PIC was my problem, but the plane I couldn't set as I didn't know it beforehand, didn't have another one of this type already and there was no network where we got to the plane.
I would really appreciate to be able to change these pieces of information.
What do others think?
Two new flights for me yesterday and today, with another plane, but I forgot to change it.
And so, I think it will be a good idea to have the ability of update these properties (plane, id)
