Position report text is difficult to read in bright light - can I change it?
Ramscroft
Ramscroft
Posts: 13, Visits: 104
Hi
On the SD MD, when you touch the aircraft to get a position report, the text is sort of grey on grey (on my unit). This can be difficult to read if there is any reflected light from outside the cockpit, because the glare from external light makes the screen a similar grey colour.
However, on the iPad, I see that the position report is yellow on dark grey, which is easier to read.
Is there a way to change the text colour on SD mobile? Alternatively, Tim, could I request a change to make the position report more readable?
Ray
SkyDemon Team (714K reputation)SkyDemon Team (714K reputation)SkyDemon Team (714K reputation)SkyDemon Team (714K reputation)SkyDemon Team (714K reputation)SkyDemon Team (714K reputation)SkyDemon Team (714K reputation)SkyDemon Team (714K reputation)SkyDemon Team (714K reputation)
We'd certainly consider it if lots of people asked for such a thing. Have you played with the brightness settings on your device, as a first port of call?
Adrian Hatton
A
Too Much Forum (59 reputation)Too Much Forum (59 reputation)Too Much Forum (59 reputation)Too Much Forum (59 reputation)Too Much Forum (59 reputation)Too Much Forum (59 reputation)Too Much Forum (59 reputation)Too Much Forum (59 reputation)Too Much Forum (59 reputation)
Posts: 3, Visits: 0
Tim Dawson - 7/15/2019 10:23:25 AM
Thanks Tim,
Yes, everything turned up to max - but is no match for bright sunshine in a low winged aircraft like the RV7....
