Position report text is difficult to read in bright light - can I change it?
Ramscroft
Ramscroft
Posts: 13, Visits: 104
Hi
On the SD MD, when you touch the aircraft to get a position report, the text is sort of grey on grey (on my unit). This can be difficult to read if there is any reflected light from outside the cockpit, because the glare from external light makes the screen a similar grey colour.
However, on the iPad, I see that the position report is yellow on dark grey, which is easier to read.
Is there a way to change the text colour on SD mobile? Alternatively, Tim, could I request a change to make the position report more readable?
Ray
This thread is seven years old and referred to a state of affairs which is no longer the state of affairs.
The position report is now shown permanently at the top of the screen. You cannot configure its colours, but the size of the text in there can be increased alongside the size of the instruments in general. Hopefully increasing the size of the text will address your problem.
Adrian Hatton
A
Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)Too Much Forum (67 reputation)
Posts: 3, Visits: 0
Tim Dawson - 7/10/2019 9:12:35 AM
Thank you Tim,
I already have everything as bright and large as allowed - it is just that the yellow text is hard to read in bright sunlight in a low winged aircraft flying down-sun in central France.....
I just wondered if a similar feature the that on the SD for iPhone of tapping the aircraft to open a high contrast position report could be enabled for the iPad devices - sounds like it is not an available option though.
