Position report text is difficult to read in bright light - can I change it?
http://forums.skydemon.aero/Topic6096.aspx
By Ramscroft - 6/5/2012 4:46:53 PM
Hi
On the SD MD, when you touch the aircraft to get a position report, the text is sort of grey on grey (on my unit). This can be difficult to read if there is any reflected light from outside the cockpit, because the glare from external light makes the screen a similar grey colour.
However, on the iPad, I see that the position report is yellow on dark grey, which is easier to read.
Is there a way to change the text colour on SD mobile? Alternatively, Tim, could I request a change to make the position report more readable?
Ray
By Adrian Hatton - 7/15/2019 10:30:20 AM
Tim Dawson - 7/15/2019 10:23:25 AM
We'd certainly consider it if lots of people asked for such a thing. Have you played with the brightness settings on your device, as a first port of call?
Thanks Tim,
Yes, everything turned up to max - but is no match for bright sunshine in a low winged aircraft like the RV7....
