What is the percentage of Generl Aviation aircrafts we can see in SkyDemo .
Me? What are you after?
Bealeyman
Bealeyman
Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)
Posts: 41, Visits: 103
Bearingless Targets is an option in SD (see Nav options) - what are these and why is there an objection to showing
SE2 Bearingless Mode c/s Targets?
Edited 2/16/2019 7:57:05 PM by Bealeyman
George Reid
George Reid
Posts: 113, Visits: 1.6K
Bearing less targets are contacts from mode C/S transponders. Their altitude is known but their position (ie direction and range) is unknown since mode C/S does not provide position information.
George E A Reid
Bealeyman
Bealeyman
George Reid - 2/16/2019 9:13:23 PM
Of course I knew this George but could not understand why SD was not interested in a similar offering from SE2 - see above.
 I have given up bothering about it now and will join you with Pilot Aware.
The SkyEcho 2 doesn't currently implement bearingless targets as we all know them from FLARM and PilotAware.
frederic
frederic
Posts: 49, Visits: 63
Many thanks everybody for your messages. I think this subject is verry interesting even it wil never replace the eyes. But every help is welkom.
I'm currently trying to configue my Trig TT21 to broadcast ADS-B out. Then I will probably investigate to buy the most appropriate ADS-B in compatible with SkyDemon.
If I understood correctly, one tips to verify that my transponder broadcasts ADS-B out is to go on flightradar24. If I see my plane, it's because it's broadcasting in ADS-B out.
Posts: 382, Visits: 2.6K
frederic - 2/18/2019 9:35:40 PM
Frederic,
I have a TT21 and have connected an uncertified GPS mouse to it to produce the ADS-B out capability. Yes, FR 24 is good for checking as is Planefinder. Your Trig TT21 also has a feature where it displays your current Lat, Lon and Ht on the display so you can verify your interface is working okay.
Tony
tnowak - 2/19/2019 7:43:45 AM
Frederic,
Tony
Is enabling ADS-B out with an uncertified GPS legal? Even if, you are contributing to 1090 congestion without being visible to the airliners. Just a short comment.
Just because an aircraft shows up on FR24 does not necessarily mean that it is equipped with ADS-B Out. FR24 can display aircraft with Mode S and no ADS-B Out, and aircraft with Mode A/C only, using a technology known as multilateration (MLAT) and ground based receivers.
26200.7840, SD 4.2.3
frederic
frederic
Tony, Markus, Mike,
Many thanks to all of you.
I am not sure that the workshop has connected my Garmin GPS to the Trig TT21 transponder. I suppose yes.
I will fly tomorrow and will take the opportunity to try to configure the transponder (GPS type, speed transfer..). I will be able to check it by displaying the ADS-B Monitor (see Tony's message).
About FR24, I understood that the signals were intercepted on the ground by a network of "private volunteers" with as main material the reading of ADS-B signals. Some of then are also equipped to receive the C / S transponder but are less numerous.
I thought it was because of this reason that I do not always see my aircraft in FR24 but sometimes only short portions of my flights ... and always at the same places. But I am not an expert on FR24 and I can, of course, be wrong
Many thanks for your help.
