bug? cannot see or set flight time under 'File Flightplan'
Easy Cruising
Easy Cruising
Posts: 50, Visits: 39
SD v.3.11.1.21395 , Samsung galaxy S8+
Route-> File Flightplan
shows message 'Please remember to set your takeoff time in the flightplan form.'
..hit 'ok' ,flightplan form appears.
Under 'Departure Time' I see date and time of flight, but if I tap it to change date or time I only see the date. Cannot see or set the time irrespective of whether I am in 'landscape' or 'portrait' mode, even though there would be space to show the time.
This was not always the case, since I previously could set the time on this screen (same device, earlier SD version) no problem.
If I go to Route-->Flight Details I can tap 'Takeoff' and the date and time appear correctly and I can set them, then go to 'File Flightplan' and the values appear.
Both ways to set the flight time should work and work the same way. Its a pain to enter the 'File Flightplan' screen, fill some details, find I cannot set the time, have to go back to 'Flight Details', set the details, then come back to 'File Flightplan', fill the same details back in and then file the plan.
This looks like a bug (or do I miss something??). Any chance of fixing this one ?
SkyDemon Team (719K reputation)SkyDemon Team (719K reputation)SkyDemon Team (719K reputation)SkyDemon Team (719K reputation)SkyDemon Team (719K reputation)SkyDemon Team (719K reputation)SkyDemon Team (719K reputation)SkyDemon Team (719K reputation)SkyDemon Team (719K reputation)
Can anyone else reproduce this issue?
Tim Dawson - 12/17/2018 10:44:30 AM
Probably not of much help, but it's working as expected for me.
26200.7840, SD 4.2.3
Andreas
Andreas
Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)
Posts: 19, Visits: 126
Sky Painter - 12/17/2018 12:49:23 PM
No, it is working well (Samsung s5/SD 3.11.1). A popop dialog is opening, I can change the times and they appear in the file flitghtplan form after.
berndalfred
b
Posts: 37, Visits: 1.7K
Same problem with a Samsung Galaxy Tab S2. With my Samsung S6 it works normal
Bernd
Easy Cruising
Easy Cruising
berndalfred - 12/17/2018 7:09:54 PM
Bernd
Easy Cruising
Easy Cruising
Andreas - 12/17/2018 3:02:52 PM
It worked ok on my S5, but that was a while ago on an earlier sd version.
It is a strange thing that only appears to happen on certain devices. Obviously, none that we have available in the office for testing, which makes it difficult for us to know what is wrong.
steveh
steveh
Posts: 1, Visits: 1
I have the same problem on my Samsung Note 8.
Setting from the flight plan page only shows the date regardless of the orientation and trying from the flight details screen shows the date and the hour (again regardless of orientation).
Or it could be the other way around, but one shows the hour as well, the other just the date.
frederic
frederic
Too Much Forum (522 reputation)Too Much Forum (522 reputation)Too Much Forum (522 reputation)Too Much Forum (522 reputation)Too Much Forum (522 reputation)Too Much Forum (522 reputation)Too Much Forum (522 reputation)Too Much Forum (522 reputation)Too Much Forum (522 reputation)
Posts: 49, Visits: 63
It works fine on my both Huawey 8" and Xiaomi Red Mi Note 4.
